查看: 1811|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 2.5 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.5运行版-64位
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-12 11:32:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2018/7/3
    包含的版本:
    2.5运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 351150096 字节 (334.88 MB)
    修改日期: 2018-07-03 17:51
    MD5: 0c9a68b172b14105721d50d4de05837e
    SHA1: ba8555d04182d3afb1ed726400cfd5ac660101f0
    SHA256: e01f7425b4cf3f27795a46dbc073099a611be5377d87a5f3a85c77e3821a52ff
    CRC32: 47d01600
    NI RFmx W-CDMA~HSPA 2.5RTE64.txt (518 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx WCDMA 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    NI-RFmx WCDMA 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxWCDMA Commit API
    NI-RFmx WCDMA 2.3 includes the following new features:
    • Addition of Code Domain Analysis (CDA) measurement
    • Addition of Slot Power measurement
    • Support for multi-carrier in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    Caution  Before you install NI-RFmx WCDMA 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx WCDMA 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx WCDMA dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx WCDMA 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx WCDMA 2.5 to an unsupported OS. Additionally, after installing NI-RFmx WCDMA 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx WCDMA 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx WCDMA. To add support for ADEs installed after installing NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or launch the NI-RFmx WCDMA installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx WCDMA will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming functions and VIs
    NI-RFmx WCDMA 2.5 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Examples.
    The following items are the behavior changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@WCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx WCDMA. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx WCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in NI-RFmx WCDMA 2.4 from NI-RFmx WCDMA 2.3.1
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx WCDMA 2.3 from NI-RFmx WCDMA 2.2.
    641152Fixed an issue with configuring User Defined Channel properties in ModAcc and SlotPhase measurements with a named signal.
    © 2015–2018 National Instruments. All rights reserved.
    375559G-01
    GMT+8, 2026-1-8 05:58
