查看: 1594|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 19.0 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试19.0运行版-64位
    发表于 2022-4-12 11:49:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2019/6/27
    包含的版本:
    19.0运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 566642688 字节 (540.39 MB)
    修改日期: 2019-07-17 14:33
    MD5: 73c56291afa884307a8f77148a7d7095
    SHA1: 1a8ffc7ae0e7f0bb43c697677afefe040bd09afe
    SHA256: 96849dbb335fd490c0e203fa4253b46fb8e1c6d5428e18bd3853a4a7bb66bc07
    CRC32: f547fa18
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 19.0RTE64.txt (552 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 19.0 Readme
    June 2019
    This file contains important information about RFmx WCDMA, including installation instructions, new features, bugs fixes, and known issues.
    RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 19.0 includes the following new features:
    • Addition of RFmx WCDMA Soft Front Panel (SFP 64-bit) with debug support
    RFmx WCDMA 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    RFmx WCDMA 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxWCDMA Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    System RequirementsRFmx WCDMA has the following requirements:
    • RAM—4 GB*
    RFmx WCDMA 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx WCDMA dropped support for all 32-bit Windows operating systems. RFmx WCDMA will not install or run on an unsupported OS. Refer to RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx WCDMA. To add support for application software installed after installing RFmx WCDMA modify your RFmx WCDMA installation or launch the RFmx WCDMA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx WCDMA
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI automates RFmx WCDMA installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx WCDMA is available for download from NI Software Product Downloads.
    Installed SoftwareInstalled Software
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx WCDMA»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx WCDMA examples at Start»All Programs»National Instruments»RFmx WCDMA»RFmx WCDMA Examples.
    Documentation for RFmx WCDMA is located at Start»All Programs»National Instruments»RFmx WCDMA»RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WCDMA HelpHTML/Windows HelpContains primary help content for RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WCDMA
    • A complete reference for all RFmx WCDMA programming functions and VIs
    RFmx WCDMA 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    The following items are behavior changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    • Dropped support for RFmx WCDMA Measurement Interactive Panel.
    The following items are the behavior changes in RFmx WCDMA 2.3.1 from RFmx WCDMA 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@WCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    The following items are the IDs and titles of a subset of issues fixed in RFmx WCDMA. This is not an exhaustive list of issues fixed in the current version of the RFmx WCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    732660Fixed an issue where the user-configured values for ModAcc IQ Gain Imbalance Removal Enabled and ModAcc IQ Quadrature Error Removal Enabled properties were not being considered in a few scenarios.
    The following items are changes in RFmx WCDMA 3.0 from RFmx WCDMA 2.5
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following item is the change in RFmx WCDMA 2.4 from RFmx WCDMA 2.3.1
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in RFmx WCDMA 2.3.1 from RFmx WCDMA 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in RFmx WCDMA 2.3 from RFmx WCDMA 2.2.
    641152Fixed an issue with configuring User Defined Channel properties in ModAcc and SlotPhase measurements with a named signal.
    RFmx WCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2015–2019 National Instruments. All rights reserved.
    375559J-01
    GMT+8, 2025-12-8 07:54
