查看: 2223|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 20.0 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试20.0运行版-64位
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2022-4-12 12:16:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2020/6/9
    包含的版本:
    20.0运行版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 582043648 字节 (555.08 MB)
    修改日期: 2020-06-09 15:48
    MD5: 24b0fcc1ba5da71570798c9ff27cd88e
    SHA1: 7bf816e6822587ac41c36ba9d3c901faadcd90f4
    SHA256: 11aeb7649e644b1dfed928f3453c21343436a23b4725f7e0933ef85023afda0a
    CRC32: d300d8e4
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 20.0RTE64.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 20.0 Readme
    June 2020
    This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions.
    RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 20.0 includes the following new features:
    RFmx WCDMA 19.1 includes the following new feature:
    RFmx WCDMA 19.0 includes the following new features:
    • Addition of RFmx WCDMA Soft Front Panel (SFP 64-bit) with debug support
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx WCDMA has the following requirements:
    RFmx WCDMA 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx WCDMA dropped support for all 32-bit Windows operating systems. RFmx WCDMA will not install or run on an unsupported OS. Refer to RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx WCDMA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx WCDMA 20.0 to an unsupported OS. Additionally, after installing RFmx WCDMA 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. To add support for application software installed after installing RFmx WCDMA modify your RFmx WCDMA installation or launch the RFmx WCDMA installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx WCDMA
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx WCDMA using NI Package Manager. If you do not already have NI software installed, RFmx WCDMA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Header files\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    Select Start » All Programs » National Instruments » RFmx WCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » All Programs » National Instruments » RFmx WCDMA » RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WCDMA HelpHTML/Windows HelpContains primary help content for RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WCDMA
    • A complete reference for all RFmx WCDMA programming functions and VIs
    RFmx WCDMA 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WCDMA examples at Start » All Programs » National Instruments » RFmx WCDMA » RFmx WCDMA Examples.
    The following are the behavior changes in RFmx WCDMA 19.1 from RFmx WCDMA 19.0.
    • Obsoleted RFmxWCDMA Analyze (IQ) and RFmxWCDMA Analyze (Spectrum) APIs. Use RFmxWCDMA Analyze (IQ, 1 Wfm) and RFmxWCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    • Dropped support for RFmx WCDMA Measurement Interactive Panel.
    You can access the RFmx WCDMA known issues online at RFmx WCDMA 20.0 Known Issues.
    You can access the RFmx WCDMA bug fix list online at RFmx WCDMA 20.0 Bug Fixes. This list describes a subset of issues fixed in RFmx WCDMA. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx WCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2020 National Instruments. All rights reserved.
    375559L-01
    GMT+8, 2026-4-18 14:51
