查看: 1970|回复: 0
[NI软件产品] NI RFmx WLAN 3.0 Full Win32/64ENG RFmx无线局域网络3.0完整版
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-13 10:44:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:
    2019/1/17
    包含的版本:
    3.0完整版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 734466000 字节 (700.44 MB)
    修改日期: 2019-01-21 17:51
    MD5: 0eeee5a163644aa2fd3f6f7e60e2b7ad
    SHA1: 32eb22f8e8ac3e608b22a8d817330f27361d2482
    SHA256: d5c21c25a3965f87b3339847d03e3c4a7160250d5004b5586ebeb9c4dfbfec3d
    CRC32: 77b8a568
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 3.0.txt (495 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx WLAN 3.0 Readme
    January 2019
    Thank you for using NI-RFmx WLAN. This file contains important information about NI-RFmx WLAN and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11ax Single-User (SU), Multi-User (MU), Extended Range SU, and Trigger-Based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D3.2.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, and 160 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    Installation InstructionsCaution  Before you install this version of NI-RFmx WLAN, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx LTE 3.0 supports the following operating systems:
    Note  NI-RFmx WLAN 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx WLAN. To add support for ADEs installed after installing NI-RFmx WLAN, modify your NI-RFmx WLAN installation or launch the NI-RFmx WLAN installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx WLAN does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WLAN\Examples
    Examples\LabVIEW \examples\RFmx\WLAN
    Select Start»All Programs»National Instruments»NI-RFmx WLAN»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Documentation for NI-RFmx WLAN is located at Start»All Programs»National Instruments»NI-RFmx WLAN»NI-RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WLAN HelpHTML/Windows HelpInformation about NI-RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WLAN
    • A complete reference for all NI-RFmx WLAN programming functions and VIs
    NI-RFmx WLAN 3.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx WLAN palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    You can access all the installed NI-RFmx WLAN examples at Start»All Programs»National Instruments»NI-RFmx WLAN»NI-RFmx WLAN Examples.
    No known issues.
    © 2019 National Instruments. All rights reserved.
    377888A-01
    GMT+8, 2026-1-8 03:10
