查看: 2132|回复: 0
[RTE运行引擎] NI RFmx WLAN 19.0 Runtime Win64ENG RFmx无线局域网络19.0运行版-32位
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-13 10:51:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:
    2019/6/27
    包含的版本:
    19.0运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32位
    文件大小: 580913152 字节 (554.00 MB)
    修改日期: 2019-07-17 15:01
    MD5: af9e26c0f3ed2dd95aab657afa2505ad
    SHA1: 81519934117f2f8f84e8cc1b947c662445a3f2e6
    SHA256: 3f186727567379c1d716982ccf02cfebe7c9c891111fb769d2a1d77cf11172a4
    CRC32: 0ac0b3ca
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 19.0RTE32.txt (554 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 19.0 Readme
    June 2019
    This file contains important information about RFmx WLAN, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11ax Single-User (SU), Multi-User (MU), Extended Range SU, and Trigger-Based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D4.2.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, and 160 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 19.0 includes the following new features:
    • Support for PXIe-5830 (EAP)
    RFmx WLAN 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for Auto Level in RFmx Soft Front Panel
    • NS_04 additional SEM requirements according to Table 6.6.2.2.3.2-3 of the 3GPP TS 36.521-1 specification (Release 12 and later)
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5840
    System RequirementsRFmx WLAN has the following requirements:
    • Processor—1 GH 64-bit (x64) processor
    • RAM—4 GB*
    RFmx WLAN 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx WLAN dropped support for all 32-bit Windows operating systems. RFmx WLAN will not install or run on an unsupported OS. Refer to RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx WLAN. To add support for application software installed after installing RFmx WLAN modify your RFmx WLAN installation or launch the RFmx WLAN installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI automates RFmx WLAN installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx WLAN is available for download from NI Software Product Downloads.
    Installed SoftwareInstalled Software
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WLAN\Examples
    Examples\LabVIEW \examples\RFmx\WLAN
    Select Start»All Programs»National Instruments»RFmx WLAN»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx WLAN examples at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Examples.
    Documentation for RFmx WLAN is located at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx WLAN palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WLAN palette.
    The following items are behavior changes in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    The following items are the IDs and titles of a subset of issues fixed in RFmx WLAN. This is not an exhaustive list of issues fixed in the current version of the RFmx WLAN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    738282Fixed an issue where two DSSS ModAcc measurements returned different results for the same waveform when run in parallel.
    RFmx WLAN will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377888B-01
    GMT+8, 2026-1-8 03:08
