查看: 1794|回复: 0
[RTE运行引擎] NI RFmx WLAN 19.1 Runtime Win64ENG RFmx无线局域网络19.1运行版-64位
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-13 10:59:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:
    2019/10/17
    包含的版本:
    19.1运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 575416320 字节 (548.76 MB)
    修改日期: 2019-10-18 16:05
    MD5: a5867cb7a463db4da478c8d48b21521d
    SHA1: 553487243174e1488516671642cbc54ab5956f8a
    SHA256: 0a8781a8ae60532b7a943b64143df6dd395c12369359f6cf16dbb093bcb291ce
    CRC32: 3b7a2d0b
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 19.1RTE64.txt (546 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 19.1 Readme
    October 2019
    This file contains important information about the RFmx WLAN, including system requirements and installation instructions.
    RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11ax Single-User (SU), Multi-User (MU), Extended Range SU, and Trigger-Based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D4.3.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, and 160 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 19.1 includes the following new features:
    • Addition of per user EVM and per user constellation traces for 802.11ax
    • Addition of preamble frequency error trace for OFDM standards
    • Support for channel estimation on L-LTF for OFDM Standards
    • Addition of PE Disambiguity attribute for Trigger based PPDU analysis
    • Support for preamble punctured MU PPDU in 802.11ax for SEM measurement
    • Support for 802.11ax MU PPDU demodulation when number of HE-SIG-B symbols exceeds 16
    • Support for 4096 QAM in 802.11ax
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    RFmx WLAN 19.0 includes the following new features:
    • Support for PXIe-5830
    RFmx WLAN 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for Auto Level in RFmx Soft Front Panel
    • NS_04 additional SEM requirements according to Table 6.6.2.2.3.2-3 of the 3GPP TS 36.521-1 specification (Release 12 and later)
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5840
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx WLAN has the following requirements:
    RFmx WLAN 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx WLAN dropped support for all 32-bit Windows operating systems. RFmx WLAN will not install or run on an unsupported OS. Refer to RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx WLAN. To add support for application software installed after installing RFmx WLAN modify your RFmx WLAN installation or launch the RFmx WLAN installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019
    If you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx WLAN using NI Package Manager. If you do not already have NI software installed, RFmx WLAN installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.WlanMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx WLAN» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WLAN examples at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx WLAN 19.1 from RFmx WLAN 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxWLAN Analyze (IQ) and RFmxWLAN Analyze (Spectrum) APIs. Use RFmxWLAN Analyze (IQ, 1 Wfm) and RFmxWLAN Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    You can access the software and documentation known issues list online. Refer to the RFmx WLAN Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx WLAN . This is not an exhaustive list of issues fixed in the current version of the RFmx WLAN . If you have a bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx WLAN 19.1 from RFmx WLAN 19.0
    234241Fixed an issue where symbol timing adjustment was incorrect in ModAcc measurement for OFDM standards.
    215013Fixed an issue where pilot subcarriers in a 26 RU configuration of a Trigger-based PPDU are used for frequency domain SCO correction in OFDM ModAcc.
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement
    The following item is the change in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    738282Fixed an issue where two DSSS ModAcc measurements returned different results for the same waveform when run in parallel.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx WLAN will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    377888C-01
    GMT+8, 2026-1-8 03:08
