查看: 2192|回复: 0
[RTE运行引擎] NI RFmx WLAN 20.7.1 Runtime x64Win10 64bitENG RFmx无线局域网络20.7.1运行版-64位
    发表于 2022-4-13 11:30:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:
    2021/7/22
    包含的版本:
    20.7.1运行版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 630654976 字节 (601.44 MB)
    修改日期: 2021-07-22 02:17
    MD5: ec6968be5ee215a0f19279db567bce40
    SHA1: 1466c384f5f45bd8868a184895d59f342a899c21
    SHA256: 04c72ed28df17ab567fdb5a13d7b96fa3a1eacc3d20f38e333b6dbbfe133601d
    CRC32: 9e1b8ae6
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 20.7.1RTE64.txt (573 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 20.7.1 Readme
    July 2021
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11be MU PPDU in SISO and MIMO configurations
    • Support for OFDM physical layer of 802.11n, 802.11ac, and 802.11ax in MIMO configuration
    • Support for OFDM physical layer of 802.11ax SU, MU, Extended Range SU, and trigger-based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D8.0.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 20.7 includes the following new features:
    • Support for MIMO measurements of 802.11n/ac/ax/be standards on PXIe-5830/5831/5832/5840/5841
    • Support for 802.11be Standard IEEE P802.11be/D0.3
      • Bandwidth support up to 320 MHz
      • Modulation scheme support up to 4096 QAM
      • MU PPDU MIMO
        • Non-OFDMA and OFDMA
        • Multi-user MIMO
        • Preamble Puncturing
      • [BETA] Trigger-based PPDU MIMO
    • Reference waveform based EVM computation support in OFDMModAcc measurement
    • Support for sample clock rate factor across all measurements
    RFmx WLAN 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx WLAN 20.0 includes the following new features:
    • Support for packet data decoding
    • Support for EVM Noise Compensation on PXIe-5830/5831
    • Support for analysis and data decoding for MCS 12 and MCS 13 in 802.11ax
    • Support for 320 MHz in 802.11ax SU PPDU for early testing of the 802.11be 320 MHz channels
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    • PXIe-5646
    RFmx WLAN 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 20.7.1 to an unsupported OS. Additionally, after installing RFmx WLAN 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
      • WLAN : Enables analysis of 802.11a/b/g/j/p/n/ac/ax/11be signals with standard-compliant physical layer measurements such as error vector magnitude (EVM), spectrum emission mask (SEM), transmit power (TXP), and more. RFmx WLAN supports single-user and advanced multi-user signals with flexible configurations, impairments, and measurement results per user.
      • WLAN MIMO : Enables analysis of 802.11n/ac/ax/be MIMO signals with standard-compliant physical layer measurements such as error vector magnitude (EVM), spectrum emission mask (SEM), transmit power (TXP), and more. RFmx WLAN supports single-user and advanced multi-user signals with flexible MIMO configurations, impairments, and measurement results per user/per chain/per segment.
    • Use the serial number that is included with your software to activate RFmx WLAN. For more information on RFmx WLAN activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx WLAN » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » All Programs » National Instruments » RFmx WLAN » RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WLAN examples at Start » All Programs » National Instruments » RFmx WLAN » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 20.6 from RFmx WLAN 20.0.
    • Noise calibration performed by OFDMModAcc EVM on PXIe-5840 and PXIe-5644/5645/5646 using earlier versions of RFmx is no longer valid. Noise calibration should be re-run before performing noise compensation.
    The following is the behavior change in RFmx WLAN 20.0 from RFmx WLAN 19.1.
    • SEM Mask creation now accounts for nearest bin quantization of offset start and stop frequencies
    You can access the RFmx WLAN known issues online at RFmx WLAN 20.7 Known Issues.
    You can access the RFmx WLAN bug fix list online at RFmx WLAN 20.7 Bug Fixes. This list describes a subset of issues fixed in RFmx WLAN. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377888G-01
    GMT+8, 2025-12-8 07:54
