查看: 2378|回复: 0
[NI软件产品] LabVIEW 2017 FPGA Module Xilinx Compilation Tools Win32Eng LV2017 FPGA编译工具(ISE 10.1)
    10 小时前
    发表于 2022-5-7 14:55:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2017Xilinx10
    发布日期
    17-5-19
    受支持的操作系统
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    文件大小: 1801908104 字节 (1.68 GB)
    修改日期: 2017-05-19 11:21
    MD5: 7d7a80a428a22e0f364d4e73aa12981c(可秒传)
    SHA1: 1913f2e2336ec15fe73da52c7abe54c8f0e94cb5
    SHA256: 0eff18ae7de81b381351b03baf88ed7281b1c0435e60b5c6e09fec0a874b3755
    CRC32: 5be819b6
    注册登录视觉论坛,购买附件查看下载地址
    LV-FPGA-CT-2017 ISE10.1.txt (562 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2017 FPGA Module Xilinx Compilation Tools for Windows Readme
    March 2017
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2015.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You must install these tools on the FPGA Module development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use the FPGA IP Builder, or use third-party simulation.
    The Xilinx compilation tools also support Linux. Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for more information.
    The Xilinx compilation tools for Windows have the following system requirements:
    • Windows 7 SP11
    • 11 GB of additional disk space for Vivado 2015.4
    • 11 GB of additional disk space for ISE 14.7
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    • In 2016 the FPGA Module Xilinx Compilation Tools dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 FPGA Module Xilinx Compilation Tools will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 FPGA Module Xilinx Compilation Tools to an unsupported OS. Additionally, after installing the LabVIEW 2017 FPGA Module Xilinx Compilation Tools, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    • The Xilinx compilation tools do not support Windows 8.1 or Windows 10. You can install the Xilinx compilation tool for Vivado 2015.4 on either of the two OSes, but you may experience unexpected issues using FPGA features that rely on this tool. Refer to the NI website for a list of known issues that you may encounter if you run this tool on Windows 10.
    • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Windows.
    Xilinx Compilation Tool for Vivado 2015.4
    Use the Xilinx Compilation Tool for Vivado 2015.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • myRIO-1900, myRIO-1950
    • NI 9145, NI 9147, NI 9149
    • NI cRIO-903x, NI cRIO-906x
    • NI ELVIS RIO Control Module
    • NI PCIe-782xR
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-784x, NI PXIe-785x, NI PXIe-786xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-784xR, NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    • roboRIO
    Xilinx Compilation Tool for ISE 14.7
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI 9144, NI 9146, NI 9148, NI 915x
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI PCIe-784xR, NI PCIe-785xR, NI PCIe-1473R
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI sbRIO-9605, NI sbRIO-9606, NI sbRIO-961x, NI sbRIO-962x (excluding NI sbRIO-9627), NI sbRIO-963x (excluding NI sbRIO-9637), NI sbRIO-964x
    Install the Xilinx Compilation Tool for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tool for ISE 10.1.
    Depending on the installation media type, you can install the Xilinx Compilation Tools for Windows in either of the following ways:
    (DVD) Insert the Xilinx compilation tools for Windows installation media and follow the instructions on the screen to complete the installation.
    (USB) Complete the following steps to install the Xilinx Compilation Tools for Windows:
    • Insert the Xilinx compilation tools installation media.
    • Depending on which tool you want to install, navigate to the Windows\Vivado2015_4 or Windows\ISE14_7 directory.
    • Double-click autorun.exe on the media to begin installation.
    • Follow the instructions on the screen to complete the installation.
    © 2012–2017 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    374738G-01
    GMT+8, 2025-12-8 19:47
