查看: 2003|回复: 0
[NI驱动程序] NI Linux Device Drivers 2022 Q2 Online Linux64Eng Linux设备驱动程序2022Q2DeviceDrivers在线安装
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2022-5-11 12:23:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Device Drivers 2022 Q2 Online Linux64Eng Linux仪器驱动程序NIlinux2022Q2DeviceDrivers在线安装
    NI Linux仪器驱动程序
    NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
    NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
    发布日期:
    2022/4/22
    包含的版本:
    2022Q2
    RedHat
    CentOS
    SUSE
    Ubuntu
    语言:
    English
    文件大小: 408572 字节 (399.00 KB)
    修改日期: 2022-04-16 05:29
    MD5: 36db65bb8bf78184539b46335b6e7c24
    SHA1: aad4ee0ce8009563d35a48cb9687dd5e689b9535
    SHA256: 687cd8690b9be02d3c1a2334929e6d7e5b6b01f1a074b4035050b185eacf9e8a
    CRC32: e7edcae2
    百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
    请注册视觉论坛会员登录后购买附件下载查看,充值请联系在线客服
    NI-Linux Device Drivers2022Q2.txt (541 Bytes, 下载次数: 0, 售价: 5 圆)
    NI Linux Device Drivers 2022 Q2 Readme
    April 2022
    This file contains installation instructions and compatibility information for NI Linux Device Drivers 2022 Q2.
    You can find more release information, such as known issues, bugs fixed since the last release, and other notes about this release, in the NI Linux Device Drivers Release Notes. For more general NI Linux information, refer to the NI Linux Users Community on ni.com.
    Package Repositories
    Supported Drivers
    NI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages.
    Refer to Download and Install NI Driver Software on Linux Desktop.
    NI Linux Device Drivers are installed from one of the following two options.
    • Static repository registration packages are labeled with a date-based suffix, such as ni-RHEL7CENTOS7-drivers-2022Q2. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
    • Stream repository registration packages are labeled with a -stream suffix, for example: ni-RHEL7CENTOS7-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
    "Firstlook" is present in repository registration package names, for example ni-ubuntu2004firstlook-drivers-2021Q3.deb, to identify a repository that does not contain one or more of the drivers present in the other feeds. This commonly occurs when NI adds support for a new Linux OS distribution and there is a transition period while individual drivers are gradually added or validated on that distribution.
    If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution.
    Supported Drivers
    For a list of supported hardware, refer to the NI Hardware and Operating System Compatibility page. For details about a specific driver's system requirements, limitations, and so on, refer to the readme for the individual driver (linked below).
    The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver.
    ​NI Driver Support for Linux Distributions(下表中空白的表示支持,NI官方是使用绿色背景表示的,论坛不支持这种表格。n/a的表格,则表示不支持)
    Driver
    Packages
    RHEL1/
    CentOS 7
    Kernel 3.10
    RHEL1 8
    Kernel 4.18
    SUSE2 15.1
    Kernel 4.12
    SUSE2 15.2
    Kernel 5.3
    Ubuntu3 18.04
    Kernel 5.4
    First Look
    Ubuntu3 20.04
    Kernel 5.8
    First Look
    Driver
    Readmes
    NI-488.2
    ni-488.2
    libni4882-devel
    ni-488.2-iotrace-support
    378677b
    Automotive Diagnostic
    Command Set Toolkit
    ni-adcs
    ni-adcs-labview-20xy-support
    libnidiagcs-devel
    378696a
    NI-DAQmx
    ni-daqmx
    ni-daqmx-labview-20xy-support
    libnidaqmx-devel
    378678c
    NI-DCPower
    ni-dcpower
    ni-dcpower-daqmx
    ni-dcpower-labview-20xy-support
    ni-dcpower-devel
    378679c
    NI-DMM
    ni-dmm
    ni-dmm-daqmx
    ni-dmm-labview-20xy-support
    ni-dmm-devel
    378680a
    ECU Measurement and
    Calibration Toolkit
    ni-ecumc
    ni-ecumc-labview-20xy-support
    libniemcc-devel
    378694b
    NI-FGEN
    ni-fgen
    ni-fgen-daqmx
    ni-fgen-devel
    ni-fgen-labview-20xy-support
    ni-fgen-labview-support
    378804a
    NI-FlexRIO
    ni-flexrio
    ni-flexrio-795x
    ni-flexrio-796x
    ni-flexrio-797x
    libniflexrioapi-devel
    ni-flexrio-modulario-libs-devel
    378681c
    Hardware Configuration
    Utility
    ni-hwcfg-utility
    378698a
    NI PXI Platform
    Services
    ni-pxiplatformservices
    ni-pxiplatformservices-labview-20xy-support
    ni-pxiplatformservices-devel
    378682c
    NI-RIO5
    ni-fpga-interface
    ni-rio-mxie
    378684a
    NI R Series
    ni-rseries
    378683a
    NI-RFSA
    ni-rfsa
    ni-rfsa-daqmx
    ni-rfsa-labview-20xy-support4
    ni-rfsa-devel
    n/a
    n/a
    378692c
    NI-RFSG
    ni-rfsg
    ni-rfsg-daqmx
    ni-rfsg-labview-20xy-support4
    ni-rfsg-devel
    n/a
    n/a
    378693c
    NI-SCOPE
    ni-scope
    ni-scope-daqmx
    ni-scope-labview-20xy-support4
    ni-scope-devel
    378685a
    NI-Serial
    ni-serial
    378686b
    NI-SWITCH
    ni-switch
    ni-switch-daqmx
    ni-switch-daqmx-config
    ni-switch-labview-20xy-support4
    ni-switch-labview-20xy-examples4
    ni-switch-devel
    378687a
    NI-Sync
    ni-sync
    ni-sync-devel
    ni-sync-labview-20xy-support
    378688b
    NI System
    Configuration
    ni-syscfg-runtime
    ni-syscfg-labview-20xy-support
    ni-iotrace
    ni-syscfg-devel
    378689b
    NI USRP-RIO
    ni-usrp-rio
    Driver Info
    NI-VISA
    ni-visa
    ni-visa-labview-20xy-support
    ni-visa-devel
    378691b
    NI-XNET
    ni-xnet
    ni-xnet-labview-20xy-support
    libnixnet-devel
    374803d
    1 Red Hat Enterprise Linux
    2 OpenSUSE Leap
    3 Ubuntu LTS
    4 LabVIEW support is not available on Ubuntu distributions for current versions of NI SWITCH, NI-SCOPE, NI-RFSG, NI-RFSA, and NI-DMM
    5 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
    For additional information about supported operating systems, refer to the NI Operating System Support Roadmap.
    © 2018–2022 National Instruments Corporation. All rights reserved.
    378353G-01
    GMT+8, 2025-12-5 13:49
