查看: 2207|回复: 0
[NI软件产品] NI Lookout 6.7 Server Win32Eng NI Lookout服务器6.7版
    昨天 09:10
  • 签到天数: 3793 天
    连续签到: 44 天
    发表于 2022-5-13 22:24:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Lookout服务器
    Lookout Server支持基于Web的工业测量和自动化功能,大幅减少了开发工作量。
    Lookout Server是一款应用软件,提供基于Web的功能,如多客户多服务器网络、Web监控和控制、OPC服务器和客户端、事件驱动处理、分布式日志记录和分布式报警。
    Lookout客户端
    Lookout Client可为要求苛刻的制造和过程控制应用提供直观的控制。
    Lookout Client是基于Web的人机界面/监控和数据采集(HMI/SCADA)系统软件。它具有网络监测和控制以及分布式警报、事件和数据记录等功能。Lookout Client采用基于对象的架构,并支持事件驱动的处理。
    Lookout6.7Server
    文件大小: 582166898 字节 (555.20 MB)
    修改日期: 2013-03-05 01:49
    MD5: 91b1af7a9e2fbf62930425a21a629b17
    SHA1: bbb926746e9e804bfc41ef67980ed382a50bb7eb
    SHA256: 828c2910340a85ef3b95ce4cceac0b50e4fb9495d36b0bf0583e0717d467f0fc
    CRC32: dddf0945
    注册登录视觉论坛账号,购买附件查看下载地址
    Lookout6.7.0Server.txt (523 Bytes, 下载次数: 0, 售价: 10 圆)
    Lookout 6.7 Readme
    January 2013
    This file contains information about Lookout 6.7, including supported platforms, installation instructions, and a list of new features and changes.
    Activation
    Features and Changes
    Upgrade Notes
    National Instruments Lookout is a human machine interface (HMI) and supervisory control and data acquisition (SCADA) software system for industrial automation. Lookout runs under Windows and communicates with field I/O through control hardware. Lookout can support the following applications:
    • Continuous process monitoring and supervisory control
    • Discrete manufacturing
    • Batch applications
    • Remote telemetry systems
    Lookout supports the following operating systems:
    • Windows XP SP3 (32-bit)
    Note: Lookout does not support Windows Me/2000/9x/NT or the Windows Server non-R2 editions.
    Lookout has the following minimum system requirements:
    • A minimum of a Pentium III or later, or Celeron 866 MHz or equivalent PC processor. National Instruments recommends a Pentium 4/M or equivalent processor.
    • A minimum of 256 MB of RAM. National Instruments recommends 1 GB of RAM.
    • A minimum of 1 GB of free disk space, plus more to store the amount of historical data you intend to log to the Citadel storage system. National Instruments also recommends that you have 1.5 GB of free disk space for file swapping.
    • A minimum screen resolution of 800 x 600 pixels. National Instruments recommends a screen resolution of 1,024 x 768 pixels.
    • Internet Explorer 6 SP1 or later.
    Note: The performance of Lookout depends on the number, size, and complexity of the processes you run. While the minimum requirements are sufficient for some processes, you might need to use more powerful computer configurations for complex and data-intensive applications.
    If you want to use the networking capabilities of Lookout, you must have a network card installed on the computer and have the computer properly set up on a network with TCP/IP protocols. You also must be able to ping any computer on the network that you intend to have as a part of the Lookout network. To test if a computer is on the Lookout network, access a command prompt and enter the following command:
    Ping compname
    where compname is the name of the computer you want to ping.
    If TCP/IP is working properly on the computer, you receive a response similar to the following example:
    Pinging compname [123.45.67.89] with 32 bytes of data:
    Reply from 123.45.67.89: bytes=32 time<10ms TTL=128
    If TCP/IP is not working properly on the computer, consult the system administrator. Refer to the Lookout Help, available by selecting Start»All Programs»National Instruments»Lookoutx.x»Lookout Help, for more information about networking and network configuration with Lookout.
    National Instruments recommends that you install Lookout 6.7 on a clean computer without previous versions of Lookout installed to obtain maximum stability. If you must install Lookout 6.7 and previous versions on the same computer, do not run multiple versions of Lookout at the same time.
    Note: If you plan to use the networking capabilities of Lookout, verify that TCP/IP is working properly on all the computers you intend to use before you install Lookout.
    Complete the following steps to install Lookout:
    • Insert the Lookout media.
      • If the computer has the AutoPlay feature enabled, the Lookout Setup window appears. Click Install Lookout to start the installation.
      • If the computer does not have the AutoPlay feature enabled, navigate to x: \Lookout, where x is the letter of the DVD-ROM drive, and run the setup.exe program to start the installation.
    • Follow the instructions on the screen.
    • Restart the Computer.
    After completing the previous installation process, refer to the following additional installation considerations for the required Lookout components.
    The Lookout software requires Microsoft SQL Server 2005 Express Edition (SQL Express). This component is installed by default when you install Lookout. During the installation process, the Lookout installer creates an instance of SQL Express named CITADEL. To prevent unauthorized access to SQL Express, the installer also generates a password for the SQL Express administrator sa. The default password is the computer ID. Complete the following steps to find the computer ID using NI License Manager.
    • Launch NI License Manager by selecting Start»All Programs»National Instruments»NI License Manager.
    • Click the Display Computer Information button in the toolbar.
    The Lookout installer enables a mixed security mode on existing SQL Servers. If the target computer does not have an SQL Server installed, the Lookout installer installs SQL Express in the mixed security mode.
    Use the following command line prompt to change the default password for the sa user:
    Sqlcmd -S"localhost\CITADEL" -U"sa" -P"COMPUTER_ID" -Q"sp_password 'COMPUTER_ID', 'NEW_PASSWORD', 'sa'"
    If the mixed security mode is not acceptable, change both the SQL Express and Citadel login modes. You must set the registry DWORD values HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\MSSQLServer\LoginMode and HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Citadel\5.0\IntegratedSecurity to 1.
    National Instruments recommends you to change the login mode immediately after you install Lookout. Otherwise, you must relink all existing Citadel databases. Restart the SQL Express and Citadel services in order for changes to take effect. If you use integrated NT security, you might need to configure the server machine and all clients explicitly.
    Note: Lookout 6.0.2 and earlier use Microsoft SQL Server 2000 Desktop Engine (MSDE 2000), not SQL Express. If you upgrade Lookout 6.0.2 or earlier to Lookout 6.7, any existing databases continue to use MSDE 2000 for alarm logging, but new databases you create use SQL Express. If you detach an existing database from Lookout and then reattach the database, Lookout migrates the database to SQL Express.
    You might want to uninstall MSDE 2000 after installing Lookout 6.7. Complete the following steps to uninstall MSDE 2000.
    • Exit Lookout if Lookout is running.
    • Open NI Measurement & Automation Explorer (MAX) and select My System»Historical Data»Citadel 5 Universe from the Configuration tree.
    • On the Databases page, detach all databases from the local computer.
    • Open the Windows Control Panel and uninstall MSDE 2000.
    • Restart the computer.
    • Open MAX and reattach all databases.
    Activation
    Lookout relies on licensing activation. You have a temporary license for a 7-day evaluation period. If you do not activate the Lookout license, Lookout runs in evaluation mode for a 7-day period. During the evaluation period, you can use only 50 I/O points and one client connection. When the evaluation period expires, you must activate a valid Lookout license to continue using Lookout. Activating Lookout includes activating the Lookout license and the Lookout Client Connection.
    Activating the Lookout License
    Use the serial number you received as part of the installation package. Activate the Lookout license in any of the following ways:
    • During installation, enter the serial number and run the NI Activation Wizard at the end of installation.
    • After you launch Lookout in evaluation mode, follow the steps in the NI Activation Wizard. If Lookout does not run this wizard, click the Activate Lookout button in the Lookout — Unlicensed Version dialog box to run this wizard.
    • Select Options»System while running Lookout in evaluation mode to display the System Options dialog box. Click the Activate Lookout button to run the NI Activation Wizard. The license activation does not take effect until you restart Lookout.
    • Select Start»All Programs»National Instruments»NI License Manager to launch NI License Manager. The license activation does not take effect until you restart Lookout.
    Note: If the activation fails, Lookout remains in evaluation mode until the 7-day evaluation period expires. If you activate Lookout by using a Development/Runtime Server license or a Runtime Only Server license, NI License Manager activates the NI OPC Servers automatically. If you activate Lookout by using a Lookout Integrator license, NI License Manager does not activate the NI OPC Servers with Lookout.
    Activating the Lookout Client Connection
    Activate the Lookout Client Connection in either of the following ways:
    • In Lookout, select Options»System to display the System Options dialog box. Click the Activate Client Connection button to run the NI Activation Wizard. The activation does not take effect until you restart Lookout.
    Note: If you do not activate the Lookout Client Connection, you cannot connect to Lookout on the local computer through Lookout clients on other computers on the same network.
    Lookout 6.7 incorporates the following new features and changes:
    Providing a Panel Navigator
    Lookout provides a panel navigator. You can switch and organize panels to enhance the user interface by using this panel navigator. Display the panel navigator by selecting View»Show Navigator from the menu bar.
    Improving Object Usability
    Lookout improves the usability for multiple objects in the following ways:
    • Support binding connections to the parameters of Pot, Pushbutton, TextEntry, and Panel;
    • Support resizing Pot and Switch;
    • Support justifying TextEntry vertically.
    Providing File Functions
    Lookout provides two more file functions:
    • FILEEXISTS file function enables you to avoid creating duplicate file names. Use this function to check whether a file exists.
    • DIREXISTS file function enables you to avoid saving files to non-existent directories. Use this function to check whether a directory exists.
    Upgrade NotesUpgrade from Lookout 6.6
    NI OPC Servers is upgraded from 2011 to 2012. In Lookout 6.7, if you want to use NI OPC Servers 2012 to run applications built in NI OPC Servers 2011, you do not need to complete any extra steps.
    Upgrade from Lookout 6.5 or earlier
    Complete the following steps to use NI OPC Servers 2012 to run applications built in NI OPC Servers 2010 or earlier:
    • Launch NI OPC Servers Configuration by selecting Start»All Programs»National Instruments»NI OPC Servers 2012»NI OPC Servers Configuration. Select File»Open from the menu bar to open the NI OPC Servers project file (.opt) built in NI OPC Servers 2010 or earlier.
    • In Lookout 6.7, select File»Open from the menu bar to open the Lookout source code file (.lks) compiled by Lookout 6.5 or earlier.
    • Switch to edit mode and select Object»Object Explorer.
    • In the Object Explorer dialog box that appears, expand your process tree and show your OPC client objects. Right-click the OPC client object you want to use and select Properties from the shortcut menu.
    • In the Revise OPC Client dialog box that appears, switch to National Instruments.NIOPCServers.V5 from the Server Name pull-down menu.
    • Click OK.
    Tip: National Instruments recommends that you save the Lookout process file (.l4p) after completing the previous steps for easier access later. If you do not save this file, you need to complete the previous steps again the next time.
    Refer to the NI OPC Servers Help, available by selecting Start»All Programs»National Instruments»NI OPC Servers 2012»NI OPC Servers Help, for more information about using the NI OPC Servers application.
    Upgrade from Lookout 5.x or earlier
    Refer to the National Instruments website at ni.com/info and enter the Info Code exd569 for information about upgrading Lookout from the earlier versions.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in Lookout.
    The following table contains the IDs and issues of a subset of fixed bugs in Lookout 6.7. This table is not an exhaustive list of fixed bugs in Lookout 6.7. If you have a CAR ID, you can search this list to validate the bug that has been fixed.
    310324
    Logon window does not show when Lookout launches at the first time.
    335417
    ABS function has problems after compiling the source file.
    343252
    Lookout crashes at launch with incorrect path in lookout.ini.
    366184
    Lookout hangs when loading certain process.
    © 1996-2013 National Instruments. All rights reserved.
    LabVIEW, Lookout, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-2-5 01:33
