查看: 2193|回复: 0
[NI软件产品] NI InstrumentStudio 2022Q2 x64Win10 64bitEng NI仪器套件2022第二季度 InstrumentStudio22.2.0
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2022-5-26 17:23:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    InstrumentStudio 2022 Q2 22.2.0
    发布日期:
    2022/4/19
    包含的版本:
    2022 Q2
    语言:
    English
    应用程序位数:
    64位
    文件大小: 794986496 字节 (758.16 MB)
    修改日期: 2022-04-16 02:45
    MD5: 92d6355f560edfcf3b77ba1edd471a0f
    SHA1: 16de261dc1e6e644194165f102a9db279f011e90
    SHA256: fcd25f24aca8435e457ee9c70021d78aead384610f5fbfc6fdc3f901aa063072
    CRC32: 9c8e72c4
    请注册登录视觉论坛,购买附件后查看下载地址
    NI InstrumentStudio2022Q2.txt (567 Bytes, 下载次数: 0, 售价: 10 圆)
    NI InstrumentStudio 2022 Q2 Readme
    April 2022
    This file contains installation instructions and compatibility information for Instrument Studio 2022 Q2.
    • InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • InstrumentStudio Manuals: New features, behavior changes, and other documentation
    InstrumentStudio allows you to generate and acquire measurements from multiple devices within a single application. You can also use InstrumentStudio to monitor and control devices being used in external applications, capture data files, export device configuration to other applications, and more.
    InstrumentStudio 2022 Q2 has the following requirements:
    • 4 GB RAM
    • 10 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    Supported Operating SystemsInstrumentStudio 2022 Q2 supports the following operating systems:
    • Windows 10 64-bit
    • Windows Server 2016 64-bit
    InstrumentStudio 2022 Q2 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Minimum Version Supported by InstrumentStudio 2022 Q2
    NI-SCOPE20.7
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER21.8
    NI-RFSG20.7
    Download the Instrument Studio 2022 Q2 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Single-channel sweep mode measurement added as a preview feature for PXIe-4190 when used in LCR mode.
    Supported HardwareNI-DCPOWER Devices
    • PXIe-4112
    • PXIe-4113
    • PXIe-4135
    • PXIe-4135(40W)
    • PXIe-4136
    • PXIe-4137
    • PXIe-4137(40W)
    • PXIe-4138
    • PXIe-4139
    • PXIe-4139(40W)
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4147
    • PXIe-4154
    • PXIe-4162
    • PXIe-4163
    • PXIe-4190
    • PXI-4110
    • PXI-4130
    • PXI-4132
    NI-DMM Devices
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • PCI-4065
    • PCIe-4065
    • USB-4065
    • PCI-4070
    NI-FGEN Devices
    • PXIe-5413 (1-channel)
    • PXIe-5413 (2-channel)
    • PXIe-5423 (1-channel)
    • PXIe-5423 (2-channel)
    • PXIe-5433 (1-channel)
    • PXIe-5433 (2-channel)
    • PXIe-5442
    • PXIe-5450
    • PXIe-5451
    • PXI-5402
    • PXI-5404
    • PXI-5406
    • PXI-5412
    • PXI-5421
    • PXI-5422
    • PXI-5441
    • PCI-5402
    • PCI-5406
    • PCI-5412
    • PCI-5421
    NI-SCOPE Devices
    • PXIe-5105
    • PXIe-5110
    • PXIe-5111
    • PXIe-5113
    • PXIe-5114
    • PXIe-5122
    • PXIe-5160 (2-channel)
    • PXIe-5160 (4-channel)
    • PXIe-5162 (2-channel)
    • PXIe-5162 (4-channel)
    • PXIe-5163
    • PXIe-5164
    • PXIe-5170 (4-channel)
    • PXIe-5170 (8-channel)
    • PXIe-5171 (8-channel)
    • PXIe-5172 (4-channel)
    • PXIe-5172 (8-channel, 325T)
    • PXIe-5172 (8-channel, 410T)
    • PXIe-5185
    • PXIe-5185 (1MΩ)
    • PXIe-5186
    • PXIe-5186 (1MΩ)
    • PXIe-5622
    • PXIe-5622 (DD)
    • PXI-5105
    • PXI-5114
    • PXI-5122
    • PXI-5124
    • PXI-5142
    • PXI-5152
    • PXI-5153
    • PXI-5154
    • PXI-5922
    • PCI-5105
    • PCI-5114
    • PCI-5122
    • PCI-5124
    • PCI-5142
    • PCI-5152
    • PCI-5153
    • PCI-5154
    • PCI-5922
    • PCIe-5155
    • USB-5132
    • USB-5133
    NI-RFSG Devices
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    Refer to the InstrumentStudio Help, accessible from ni.com, for information about the InstrumentStudio.
    InstrumentStudio no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2018–2022 National Instruments Corporation. All rights reserved.
    377562K-01
    GMT+8, 2025-12-5 13:51
