查看: 1704|回复: 0
[RTE运行引擎] NI RFmx 21.8.0 Runtime x64Win10 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.8.0
    昨天 08:11
  • 签到天数: 3823 天
    连续签到: 16 天
    发表于 2022-5-27 11:56:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/4/19
    包含的版本
    21.8.0运行版
    受支持的操作系统
    应用程序位数
    32位
    语言
    English
    校验和
    文件大小: 749901824 字节 (715.16 MB)
    修改日期: 2022-04-20 08:28
    MD5: 334265f6c3a2cb9e06e529c7244cf196
    SHA1: bded29b0757790ea45bd53641e3b63464588f876
    SHA256: b29cebbccf472000315bba2befd7c202afc01b69afad1c75c9ff01b7309ffe67
    CRC32: 3881c580
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFmx21.8.0RTE32.txt (600 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (32-Bit) 21.8 Readme
    April 2022
    This file contains important information about the RFmx Runtime (32-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (32-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (32-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (32-Bit)
    • RFmx Demod Runtime (32-Bit)
    • RFmx WLAN Runtime (32-Bit)
    • RFmx for Bluetooth® Test Runtime (32-Bit)
    • RFmx NR Runtime (32-Bit)
    • RFmx LTE Runtime (32-Bit)
    • RFmx WCDMA Runtime (32-Bit)
    • RFmx TD-SCDMA Runtime (32-Bit)
    • RFmx EV-DO Runtime (32-Bit)
    • RFmx CDMA2k Runtime (32-Bit)
    • RFmx GSM Runtime (32-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (32-Bit) has the following requirements:
    RFmx Runtime (32-Bit) 21.8 supports the following 64-bit operating systems:
    Note RFmx Runtime (32-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (32-Bit) 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (32-Bit) 21.8 to an unsupported OS. Additionally, after installing RFmx Runtime (32-Bit) 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Download the RFmx Runtime (32-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    377997J-01
    GMT+8, 2026-3-13 05:27
