查看: 1522|回复: 0
[RTE运行引擎] NI RFmx 21.8.1 Runtime x64Win10 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.8.1
    发表于 2022-5-27 12:00:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/4/30
    包含的版本
    21.8.1运行版
    受支持的操作系统
    应用程序位数
    32位
    语言
    English
    校验和
    文件大小: 913324032 字节 (871.01 MB)
    修改日期: 2022-04-30 09:46
    MD5: 461f29b3cd6b7f5375d47543bec340f4
    SHA1: 6d933852f513fa41db97955b17be22a62a001829
    SHA256: e32248700713ded53a84869234f8e318ac4c4f2d5d1aebeca75ad561248a4e9b
    CRC32: a2349b8e
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFmx21.8.1RTE32.txt (600 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 21.8.1 Readme
    April 2022
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 21.8.1 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.8.1 to an unsupported OS. Additionally, after installing RFmx 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx 21.8.1 supports the following application software versions, including service packs.
    Versions Supported by RFmx
    LabWindows™/CVI™2015 or later
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    377996K-01
    GMT+8, 2025-12-8 01:10
