查看: 1783|回复: 0
[NI驱动程序] NI RF Signal Analyzers 21.8.0 x64Win10 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 21.8.0
    10 小时前
  • 签到天数: 3839 天
    连续签到: 32 天
    发表于 2022-5-27 14:30:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    发布日期
    2022/4/17
    包含的版本
    21.8.0完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 4972083200 字节 (4.63 GB)
    修改日期: 2022-04-18 10:16
    MD5: a381ac88b408aa398c4fd2b05c564173(官方正确)
    SHA1: cc668aea7f0a231727db730ac32fa45919b6e27d
    SHA256: 5d8eea596fd79314b47ebb35029425cd77d296808842e029146a20ad753b03d6
    CRC32: ab19af05
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSA21.8.0.txt (525 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSA 21.8 Readme
    April 2022
    This file contains installation instructions and compatibility information for NI-RFSA.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 21.8 includes the following new features:
    • Support for NI Linux® Real-Time
    NI-RFSA 21.5 includes the following new features:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Downconverter Frequency Offset Mode, and Signal Bandwidth attributes
    NI-RFSA 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    • 4 GB RAM*
    • Windows 10 with all available critical updates and service packs
    NI-RFSA 21.8 and NI-RFSA SFP 21.8 support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSA
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2018 to current
    LabVIEW Real-Time Module2021
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    NI RF Signal Analyzers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, and legal notices.
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    374797AJ-01
    GMT+8, 2026-3-28 17:26
