查看: 1962|回复: 0
[NI驱动程序] NI RF Signal Analyzers 21.0.1 x64Win10 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 21.0.1
    昨天 08:12
  • 签到天数: 3859 天
    连续签到: 52 天
    发表于 2022-5-27 14:50:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    发布日期
    2022/3/25
    包含的版本
    21.0.1完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 4614639616 字节 (4.30 GB)
    修改日期: 2022-03-25 09:58
    MD5: 05c3ae8f6f59472a8308fc7f9cbd44a6
    SHA1: 63de76ea05e90d77f343be382e0153acc36e52a4
    SHA256: 9b4688a409fe877728951a6874bc73cf3926410e8a8b8c4fafc6b4950685da3b
    CRC32: acc0f7d5
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSA21.0.1.txt (518 Bytes, 下载次数: 0, 售价: 10 圆)
    NI RF Signal Analyzers (NI-RFSA) 21.0 Readme
    August 2021
    This file contains installation instructions and compatibility information for NI-RFSA.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    NI-RFSA 20.7 includes peer-to-peer support for the PXIe-5668
    NI-RFSA 20.5.4 includes a bug fix to address a .NET initialization issue for PXIe-5830/1/2 devices in RFmx
    NI-RFSA 20.5 includes the following new features:
    • Support for the PXIe-5832
    • Support for selected ports in configuration lists on the PXIe-5830/5831/5832
    NI-RFSA 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for RF list mode on the PXIe-5841 with PXIe-5655
    Hardware Product
    Hardware Model
    NI-RFSA
    RF Signal DownconverterPXI-5600
    PXIe-5601
    PXIe-5603
    PXIe-5605
    PXIe-5606
    Vector Signal AnalyzerPXI-5661
    PXIe-5663/5663E
    PXIe-5665
    PXIe-5667
    PXIe-5668
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5832
    PXIe-5840
    PXIe-5841
    RF Analog Signal Generator
    RF Preselector ModulePXIe-5693
    IF Conditioning ModulePXIe-5694
    RF AmplifierPXIe-5698
    • 4 GB RAM*
    • Windows 10 with all available critical updates and service packs
    NI-RFSA 21.0 and NI-RFSA SFP 21.0 support the following operating systems:
    Versions Supported by NI-RFSA
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2017 to current
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    NI RF Signal Analyzers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, and legal notices.
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374797AG-01
    GMT+8, 2026-4-18 01:37
