查看: 2402|回复: 0
[NI软件产品] NI Circuit Design Suite 14.3 Pro x64Win10 32/64bitEng/Ger NI电路设计套件14.3专业版
    昨天 08:31
  • 签到天数: 3814 天
    连续签到: 7 天
    发表于 2022-6-6 12:07:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    Win32/64 Eng/Ger
    14.3Pro
    文件大小: 942567424 字节 (898.90 MB)
    修改日期: 2022-04-28 11:49
    MD5: 7b177dac69d9d84677535f6fa6a3de83(官方正确)
    SHA1: 8aa385392d534a0dc9b0859481304b9055f0be8c
    SHA256: 1e5f427ddcccf67368fb10b5ebd34e24946594bbdb59acaf3ac8b8647fdc6b60
    CRC32: d8626b4a
    注册登录视觉论坛,购买附件查看下载地址
    CDS14.3Pro.txt (619 Bytes, 下载次数: 0, 售价: 10 圆)
    Circuit Design Suite 14.3 Readme
    May 2022
    This file contains installation instructions and compatibility information for Circuit Design Suite 14.3.
    • Circuit Design Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Circuit Design Suite 14.3 has the following minimum requirements:
    • Pentium 4M or equivalent (32-bit)
    • Pentium 4 G1 or equivalent (64-bit)
    • 1 GB RAM
    • 2 GB of disk space
    • 1024 x 768 screen resolution
    • (Optional) LabVIEW 2019 or later, to develop custom LabVIEW-based Multisim instruments
    Circuit Design Suite 14.3 supports the following operating systems:
    • Windows Server 2012 R2
    Note Circuit Design Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Circuit Design Suite 14.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Circuit Design Suite 14.3 to an unsupported OS. Additionally, after installing Circuit Design Suite 14.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Circuit Design Suite 14.3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by Circuit Design Suite 14.3
    LabVIEW2019, 2020, 2021
    If you are using the Circuit Design Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The Circuit Design Suite 14.3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Circuit Design Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Circuit Design Suite. For more information on Circuit Design Suite activation, refer to Activating a Product.
    Installing Multiple Versions
    Circuit Design Suite 14.3 installs side-by-side with Circuit Design Suite 13.x and prior.
    Archiving Circuit Design Suite databases
    NI recommends regularly creating back-ups of files created within the Multisim and Ultiboard components of Circuit Design Suite. Additionally, you should back-up internal files that store user-created data, such as Master, Corporate, and User databases. These files can be found from Options»Global Options»Paths.
    Circuit Design Suite 14.3 Updates and Notifications
    NI posts information about critical updates and security notifications on ni.com. Visit ni.com/info and enter Info Code updates to access this information.
    When installing Circuit Design Suite, the "Circuit Design Suite Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using Circuit Design Suite with LabVIEW 2022 or later.
    LVAddons directory location:
    • Windows C:\Program Files\NI\LVAddons
    • Linux /usr/local/natinst/share/lvaddons
    • macOS /Library/Application Support/National Instruments/LVAddons
    • For information on new components, refer to New and Updated Multisim Database Components and Models.
    • For information on new Multisim Desktop components, refer to: NI Multisim Components and Models.
    • Updated obsolescence information for components.
    • Removed deprecated MCU module.
    For more information on the Circuit Design Suite, refer to Getting Started with NI Circuit Design Suite. Access this guide by clicking Start»All Programs»National Instruments»Circuit Design Suite 14.3 Documentation»Getting Started.
    For more information on NI Multisim, refer to the Multisim Help, accessible in the application from Help»Multisim help.
    For more information on NI Ultiboard, refer to the Ultiboard Help, accessible in the application from Help»Ultiboard help.
    Circuit Design Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2006–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-4 07:27
