查看: 1748|回复: 0
[NI驱动程序] NI-RFSG Playback Library 21.8.1 x64Win10 32/64bitEng NI-RFSG回放库21.8.1完整版下载
    9 分钟前
  • 签到天数: 3537 天
    连续签到: 7 天
    发表于 2022-6-9 17:40:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期
    2022/4/28
    包含的版本
    21.8.1完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 463958016 字节 (442.46 MB)
    修改日期: 2022-06-09 15:41
    MD5: e0c575683c47c8a38fc34428599f957f
    SHA1: 42366b03df3036423fb40458de42d97717610412
    SHA256: 0c9af952e6a46c21897ffbe33efe80ec0cd61ae645bb5b7a703e9a1b93d34403
    CRC32: 59787be9
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFSG PlayBack21.8.1.txt (563 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG Playback Library 21.8.1 Readme
    April 2022
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 21.3 includes the following new features:
    NI-RFSG Playback Library 20.6 includes the following new features:
    • Support for PXIe-5832
    NI-RFSG Playback Library 20.0 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 21.8.1 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 21.8.1 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library
    LabVIEW2018, 2019 SP1, 2020 SP1, 2021
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG Playback Library HelpHTML/Windows HelpContains primary help content for NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions and VIs
    NI-RFSG Playback Library 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Examples.
    375556W-01
    GMT+8, 2025-5-12 07:53
