查看: 1789|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 21.8.0 Runtime x64Win10 64bitENG运行版下载
 楼主| 发表于 2022-6-17 10:24:57 | 显示全部楼层 |阅读模式
RFmx CDMA2000
发布日期:
2022/4/19
包含的版本:
21.8.0运行版
应用程序位数:
64位
语言:
英文
文件大小: 606609408 字节 (578.51 MB)
修改日期: 2022-04-19 20:45
MD5: feac02d894c63a68f01863e720bc579d(官方正确)
SHA1: 48a64fee4204ba21a9a4b4b12072d087565b7543
SHA256: 542722d387e369e21df6949468f37da32a0090cbbeed24ec7173b6c9c253b5cb
CRC32: d52ca64d
注册登录视觉论坛,购买附件查看下载地址
RFmx CDMA2K21.8.0RTE64.txt (584 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx CDMA2k 21.8 Readme
April 2022
  • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
  • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
RFmx CDMA2k 21.3 includes the following new feature:
RFmx CDMA2k 20.0 includes the following new features:
RFmx CDMA2k 19.1 includes the following new feature:
RFmx CDMA2k 21.8 supports the following 64-bit operating systems:
Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 21.8 to an unsupported OS. Additionally, after installing RFmx CDMA2k 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
Versions Supported by RFmx CDMA2k
Item
Installed Location
Import Library files
Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
Select Start » National Instruments » RFmx CDMA2k » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » NI-RFmx » CDMA2K palette.
Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k » RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
Document
Format
Description
RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
  • An introduction to RFmx CDMA2k
  • A complete reference for all RFmx CDMA2k programming functions and VIs
RFmx CDMA2k 21.8 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k » RFmx CDMA2k Examples.
The following are the behavior changes in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
375524U-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 12:53
