查看: 1672|回复: 0
[NI软件产品] NI RFmx Waveform Creator 21.8.1 Full x64Win10 32/64bitENG RFmx波形创造器21.8.1完整版
    10 小时前
     楼主| 发表于 2022-6-20 11:25:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2022/4/30
    包含的版本:
    21.8.1完整版
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 719161344 字节 (685.85 MB)
    修改日期: 2022-04-30 01:46
    MD5: 3c9b5b52227a355fece9d5fa573fb577(官方正确)
    SHA1: b79573debcd2979b7a46431a2dddb782b6975e9d
    SHA256: 9cf88c45fa4bcd6dcdad7ae6be50cf1539dc0152e0d5b4f2b8886ec5357a0767
    CRC32: 5cecbd2a
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Creator21.8.1.txt (598 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Waveform Creator 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx Waveform Creator, including system requirements, and installation instructions.
    • RFmx Waveform Creator Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Waveform Creator Manuals: New features, behavior changes, and other documentation
    RFmx Waveform Creator provides a unified interface for creating and generating waveforms for multiple wireless standards. You can create unencrypted, unlocked IQ waveform files for playback on NI PXI RF instrumentation. Supported standards include 5G NR, LTE/LTE-Advanced, W-CDMA/HSPA+, GSM/EDGE+, TD-SCDMA, and more.
    RFmx Waveform Creator 21.8 includes the following new features:
    • Support for Enhanced Trigger Frame Generation for WLAN 802.11be standard
    • Support for 3GPP NR Release 17 (December 2021 Release)
    • Support for configurable Cell ID in Downlink Test Models
    RFmx Waveform Creator 21.5 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.3 compliant waveform creation
    RFmx Waveform Creator 21.3 includes the following new features:
    • WLAN
      • Support for 802.11be Standard IEEE P802.11be/D1.1 compliant waveform creation
    • NR
      • Support for SSB periodicity 5, 10, 20, 40, 80, and 160 milliseconds
      • Support for xOverhead configuration as per 3GPP 38.214 specification
    RFmx Waveform Creator has the following requirements:
    RFmx Waveform Creator 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx Waveform Creator no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Waveform Creator 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Waveform Creator 21.8.1 to an unsupported OS. Additionally, after installing RFmx Waveform Creator 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Waveform Creator supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Waveform Creator. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application Software
    Versions Supported by RFmx Waveform Creator
    LabVIEW2018 SP1 f4 patch, 2019 SP1, 2020 SP1, 2021
    • NI-RFSG 14.5 or later
    • NI-RFSG 20.7 or later (for MIMO configurations with PXIe-5830/5831/5832 in RFmx Waveform Creator for WLAN)
    If you are using the RFmx Waveform Creator .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Waveform Creator .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Waveform Creator installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Waveform Creator. For more information on RFmx Waveform Creator activation, refer to National Instruments Software Activation.
    Select Start » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator.
    Documentation for RFmx Waveform Creator is located at Start » National Instruments » RFmx Waveform Creator » RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx Waveform Creator HelpHTML/Windows HelpContains primary help content for RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Waveform Creator
    • A complete reference for all RFmx Waveform Creator programming functions and VIs
    RFmx Waveform Creator 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Waveform Creator examples at Start » National Instruments » RFmx Waveform Creator » RFmx Waveform Creator Examples.
    The following items are the behavior changes in RFmx Waveform Creator 21.8 from RFmx Waveform Creator 21.5.
    • If there are multiple Tx antenna streams, the NR SSB and PDCCH are now mapped on all the antenna streams instead of just the first antenna stream.
    • Dropped support for PDSCH Present in SSB Resource Block
    The following items are the behavior changes in RFmx Waveform Creator 21.3 from RFmx Waveform Creator 20.7/20.7.1.
    • Loading IQ waveform files is no longer supported in RFmx Waveform Creator for WLAN
    The following items are the behavior changes in RFmx Waveform Creator 20.0 from RFmx Waveform Creator 19.1.
    • Changed the data content of downlink NR test models from all-zero to PN23 sequence with respect to the changes in 3GPP TS 38.141v specification
    • Changed modulation scheme for downlink NR test model 3.3 to QPSK with respect to the changes in 3GPP TS 38.141-1 v16.3.0 specification
    • Changed the NR grid size for 100 MHz channel bandwidth and 240 kHz subcarrier spacing to 33.
    • Changed the NR SS/PBCH block parameters CRB Offset and Subcarrier Offset to be 3GPP specification compliant.
    • Changed the NR grid alignment for SS/PBCH block.
    © 2017–2022 National Instruments Corporation. All rights reserved.
    377066R-01
    GMT+8, 2025-12-8 19:53
