查看: 1735|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 21.8.1 Runtime x64Win10 32bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试21.8.1运行版-32位
     楼主| 发表于 2022-6-20 12:04:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI RFmx W-CDMA/HSPA+ 21.8.1 Runtime x64Win10 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试21.8.1运行版-64位
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2022/4/30
    包含的版本:
    21.8.1运行版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 1077321728 字节 (1.00 GB)
    修改日期: 2022-04-30 01:45
    MD5: ccb6dfad62a53a06ca7928e1b57e6c54(官方正确)
    SHA1: fac900bffe1543dc7908fd6d6cdb21d13e39b82d
    SHA256: abe1df82503b61cffe314feec6dc82383b9d8e067f1f3e427276f695f3972577
    CRC32: 0aaad4c8
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WCDMA21.8.1RTE64.txt (585 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions.
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 21.8 includes the following new feature:
    • Support for Downlink in Link Direction property of ModAcc measurement
    RFmx WCDMA 21.3 includes the following new features:
    RFmx WCDMA 20.0 includes the following new features:
    RFmx WCDMA has the following requirements:
    RFmx WCDMA 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 21.8.1 to an unsupported OS. Additionally, after installing RFmx WCDMA 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    Select Start » National Instruments » RFmx WCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA » RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx WCDMA HelpHTML/Windows HelpContains primary help content for RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WCDMA
    • A complete reference for all RFmx WCDMA programming functions and VIs
    RFmx WCDMA 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    The following are the behavior changes in RFmx WCDMA 19.1 from RFmx WCDMA 19.0.
    • Obsoleted RFmxWCDMA Analyze (IQ) and RFmxWCDMA Analyze (Spectrum) APIs. Use RFmxWCDMA Analyze (IQ, 1 Wfm) and RFmxWCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    • Dropped support for RFmx WCDMA Measurement Interactive Panel.
    375559V-01
    GMT+8, 2025-12-8 07:55
