查看: 1654|回复: 0
[RTE运行引擎] NI RFmx for Bluetooth Test 19.0 Runtime Win32Eng RFmx蓝牙测试NIRFmxBluetooth19.0运行版32位
    昨天 09:54
  • 签到天数: 3808 天
     楼主| 发表于 2022-7-6 15:33:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2019/6/27
    包含的版本:19.0运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    应用程序位数:32位
    校验和
    文件大小: 599851008 字节 (572.06 MB)
    修改日期: 2022-03-25 22:09
    MD5: 8f28049dc404d9dfa074b9777dfac370
    SHA1: b30fd2208a635269dd907f1ae0f1eeb970d59647
    SHA256: 6e774ec518bd7dde6977d4866607070e34059cc7e74e1057ffe0697b52a3f59a
    CRC32: 96fb5345
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmxBT19.0RTE32.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Bluetooth 19.0 Readme
    June 2019
    This file contains important information about the RFmx Bluetooth, including installation instructions, new features, bugs fixes, and known issues.
    RFmx Bluetooth Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Bluetooth supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.0, and the Bluetooth RF PHY test specifications RF.TS.5.0.2 and RF-PHY.TS.5.0.3.
    • Support for Low Energy Direction Finding physical layer confirming to Bluetooth Core Specification v5.1.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    RFmx Bluetooth 19.0 includes the following new features:
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    RFmx Bluetooth has the following requirements:
    • 4 GB RAM*
    RFmx Bluetooth 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx Bluetooth dropped support for all 32-bit Windows operating systems. RFmx Bluetooth will not install or run on an unsupported OS. Refer to RFmx Bluetooth Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx Bluetooth supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx Bluetooth. To add support for application software installed after installing RFmx Bluetooth modify your RFmx Bluetooth installation or launch the RFmx Bluetooth installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Versions Supported by RFmx Bluetooth
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx Bluetooth .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Bluetooth .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs RFmx Bluetooth using NI Package Manager. If you do not already have NI software installed, RFmx Bluetooth installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed SoftwareInstalled Software
    Item
    Installed Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\BT\Examples
    Examples\LabVIEW \examples\RFmx\BT
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BluetoothMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx Bluetooth»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx Bluetooth examples at Start»All Programs»National Instruments»RFmx Bluetooth»RFmx Bluetooth Examples.
    Documentation for RFmx Bluetooth is located at Start»All Programs»National Instruments»RFmx Bluetooth»RFmx Bluetooth Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx Bluetooth HelpHTML/Windows HelpContains primary help content for RFmx Bluetooth. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Bluetooth
    • A complete reference for all RFmx Bluetooth programming functions and VIs
    RFmx Bluetooth 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx Bluetooth palette VIs are available from the Functions»Measurement I/O»NI-RFmx»Bluetooth palette.
    The following items are behavior changes in RFmx Bluetooth 19.0 from RFmx Bluetooth 3.0.
    RFmx Bluetooth will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377890B-01
    GMT+8, 2026-2-26 06:56
