查看: 1657|回复: 0
[RTE运行引擎] NI RFmx for Bluetooth Test 19.1 Runtime Win32Eng RFmx蓝牙测试NIRFmxBluetooth19.1运行版32位
    昨天 09:54
  • 签到天数: 3808 天
     楼主| 发表于 2022-7-6 15:38:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2019/10/17
    包含的版本:19.1运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    应用程序位数:32位
    校验和
    文件大小: 600035328 字节 (572.24 MB)
    修改日期: 2022-03-25 22:09
    MD5: 0a538894d3e767b40b9c79f69af1a15b
    SHA1: ed0f69cc0d609431ebf8c9f61a67febd469f4ef6
    SHA256: 6dddebedc397bb7628660be4d13d1fdf82d71abaece8ba854ff5f6dbd174aec3
    CRC32: 81cf06e8
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmxBT19.1RTE32.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Bluetooth 19.1 Readme
    October 2019
    This file contains important information about the RFmx Bluetooth, including system requirements and installation instructions.
    RFmx Bluetooth Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Bluetooth supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.1, and the Bluetooth RF PHY test specifications RF.TS.5.1.0 and RF-PHY.TS.5.1.1.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.1.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    RFmx Bluetooth 19.1 includes the following new features:
    • Support for PXIe-5841
    • Support for angle of departure transmitter tests on low energy physical layer signals
    RFmx Bluetooth 19.0 includes the following new features:
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx Bluetooth has the following requirements:
    RFmx Bluetooth 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Bluetooth dropped support for all 32-bit Windows operating systems. RFmx Bluetooth will not install or run on an unsupported OS. Refer to RFmx Bluetooth Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx Bluetooth supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx Bluetooth. To add support for application software installed after installing RFmx Bluetooth modify your RFmx Bluetooth installation or launch the RFmx Bluetooth installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Versions Supported by RFmx Bluetooth
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019
    If you are using the RFmx Bluetooth .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Bluetooth .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx Bluetooth using NI Package Manager. If you do not already have NI software installed, RFmx Bluetooth installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx Bluetooth» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx Bluetooth palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Bluetooth palette.
    Documentation for RFmx Bluetooth is located at Start»All Programs»National Instruments»RFmx Bluetooth»RFmx Bluetooth Documentation . The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx Bluetooth HelpHTML/Windows HelpContains primary help content for RFmx Bluetooth. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Bluetooth
    • A complete reference for all RFmx Bluetooth programming functions and VIs
    RFmx Bluetooth 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Bluetooth examples at Start»All Programs»National Instruments»RFmx Bluetooth»RFmx Bluetooth Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx Bluetooth 19.1 from RFmx Bluetooth 19.0.
    • Obsoleted RFmxBT Analyze (IQ) API. Use RFmxBT Analyze (IQ, 1 Wfm) API instead
    • A warning is thrown if the measurement fails to detect start of the packet when you set the Burst Sync Type property to Preamble
    The following items are behavior changes in RFmx Bluetooth 19.0 from RFmx Bluetooth 3.0.
    You can access the software and documentation known issues list online. Refer to the RFmx Bluetooth Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx Bluetooth . This is not an exhaustive list of issues fixed in the current version of the RFmx Bluetooth . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx Bluetooth 19.1 from RFmx Bluetooth 19.0
    ID
    Fixed Issue
    217592Fixed an issue where the computed acquisition length did not include VBW filter group delay for TxP measurement.
    235284Fixed an issue of intermittent failure in auto detection of signal utility.
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ API when performing a composite measurement with different averaging count for each measurement.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx Bluetooth will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    377890C-01
    GMT+8, 2026-2-26 06:58
