查看: 1674|回复: 0
[NI软件产品] NI RFmx 21.8.2 Full x64Win10 32/64bitEng NI Wireless Test Standard Software完整版ni-rfmx-suite_21.8.2
    昨天 07:53
     楼主| 发表于 2022-7-7 11:01:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2022/6/30
    包含的版本:21.8.6完整版
    文件大小: 6002728960 字节 (5.59 GB)
    修改日期: 2022-06-29 21:48
    MD5: 0878d85a158ca3df671642ae50292be2
    SHA1: 4d40d3c248968dc603e1ba6ce76054279f03c136
    SHA256: 47b1f72c67aabbb5041c03080cebfb359d715b2f429a64f608ca7dcae89605f0
    CRC32: cbfade34
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx21.8.2.txt (557 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 21.8.2 Readme
    May 2022
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 21.8.2 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.8.2 to an unsupported OS. Additionally, after installing RFmx 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx 21.8.2 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabWindows™/CVI™2015 or later
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    377996K-01
    GMT+8, 2026-4-24 05:48
