查看: 1615|回复: 0
[NI软件产品] NI RFmx EV-DO 2.3.1 Win32/64Eng 1xEV-DO蜂窝测试软件2.3.1
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2022-7-8 16:17:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2017/10/16
    包含的版本:2.3.1
    Windows 10
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 693927904 字节 (661.78 MB)
    修改日期: 2022-03-25 22:14
    MD5: 3b0b160eddfb2d2b414cff21016363b2
    SHA1: e1795c177445e49861a0729f0c8eaf84f7b42692
    SHA256: 34e3ee07bd07ced0d885289f1b5c43c5a98676e7a89e594970e7c91d5ab0b8b4
    CRC32: f69d99ef
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO2.3.1.txt (495 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 382005248 字节 (364.31 MB)
    MD5: 10a166edb8df12599c35134ce69d752a
    SHA1: 2e085943c2c16d577fcb7e325efb0043ff5260c8
    SHA256: 1ff425de37a12e02fcb4b04f085d628fc2af2943664b3f4fb147afd493a04e3b
    CRC32: ae6488ee
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.3.1RTE32.txt (507 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 379318296 字节 (361.75 MB)
    MD5: 3a6d3dd6b6b2016317854b61229f5552
    SHA1: 2437b8ab91e9f00ceac67e8936779a64dd2b0c63
    SHA256: 8ed7d29d0b8f6f57805a05d10678ee458565c4c5947e8b529fd54854a39b22cd
    CRC32: 5c02af5b
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.3.1RTE64.txt (507 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx EV-DO 2.3.1 Readme
    October 2017
    This file contains important information about NI-RFmx EV-DO and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx EV-DO
    NI-RFmx EV-DO 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Power measurement
    • Addition of Slot Phase measurement
    NI-RFmx EV-DO 2.2 includes the following new features:
    • Addition of I/Q gain imbalance and I/Q quadrature error measurement results in ModAcc measurement
    • Improved robustness of channel and data modulation auto detection in ModAcc measurements
    • Support for reading measurement configuration internally used by RFmx for spectral measurements
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer
    NI-RFmx EV-DO 2.1 f4 includes the following bug fixes and updates:
    • Fixed an issue where NI-RFmx was crashing when the memory usage in a process increased beyond 2 GB.
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    • For the Analysis-Only mode, user needs to adjust the t0 value of the I/Q waveforms according to pre-trigger samples present in the waveform before passing the waveform to the Analyze (IQ) function.
    Caution  Before you install NI-RFmx EV-DO 2.3.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx EV-DO 2.3.1 supports the following operating systems:
    Note  NI-RFmx EV-DO 2.3.1 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx EV-DO. To add support for ADEs installed after installing NI-RFmx EV-DO, modify your NI-RFmx EV-DO installation or launch the NI-RFmx EV-DO installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016 or 2017
    Note  NI-RFmx EV-DO will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\EV-DO\Examples
    Examples\LabVIEW \examples\RFmx\EVDO
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Measurement Interactive Panel to launch the NI-RFmx EV-DO Measurement Interactive Panel.
    Documentation for NI-RFmx EV-DO is located at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx EV-DO HelpHTML/Windows HelpInformation about NI-RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx EV-DO
    • A complete reference for all NI-RFmx EV-DO programming functions and VIs
    NI-RFmx EV-DO 2.3.1 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    NI-RFmx EV-DO palette VIs are available from the Functions»Measurement I/O»NI-RFmx»EV-DO palette.
    You can access all the installed NI-RFmx EV-DO examples at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Examples.
    NI-RFmx EV-DO 2.3.1 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx EV-DO drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx EV-DO 2.3.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx EV-DO 2.3.1 to an unsupported OS. Additionally, after installing NI-RFmx EV-DO 2.3.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx EV-DO 2.3.1 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx EV-DO 2.3.1 installation, the following software is installed. To completely remove the NI-RFmx EV-DO 2.3.1 installation from your system, you must also remove the following package:
    • NI-RFmx EV-DO Runtime 2.3.1
    • NI-RFmx EV-DO Runtime 2.3.1 (64-bit)
    The following items are the behavior changes in NI-RFmx SpecAn 2.3.1 from NI-RFmx SpecAn 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty sting).
    • The alias 'default@EVDO' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx EV-DO 2.3.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx EV-DO 2.3.1.
    The following items are changes in NI-RFmx EV-DO 2.3.1 from NI-RFmx EV-DO 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead and waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx EV-DO 2.3 from NI-RFmx EV-DO 2.2.
    623679Fixed an issue with measurement of small EVMs (close to 0%) when no input signal is present in the ModAcc measurement.
    The following items are changes in NI-RFmx EV-DO 2.1 from NI-RFmx EV-DO 2.0.
    563070Fixed an issue with fetching scalar results from the property node when traces are disabled in the NI-RFmx EV-DO ModAcc measurement.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2015–2017 National Instruments. All rights reserved.
    375526E-01
    GMT+8, 2025-12-6 08:55
