查看: 1553|回复: 0
[NI软件产品] NI RFmx EV-DO 20.6 Win32/64Eng 1xEV-DO蜂窝测试软件20.6
    昨天 09:54
  • 签到天数: 3808 天
     楼主| 发表于 2022-7-8 16:52:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2021/1/20
    包含的版本:20.6
    Windows 8.1 64-bit
    Windows 7 (SP1) 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 784699392 字节 (748.35 MB)
    修改日期: 2022-03-25 09:45
    MD5: f4f994f59746c08407526aab96547aa6
    SHA1: 0fa5670546eef46129dd6856af3b5959beab91d1
    SHA256: fadabf4737e2241cfb52126992176720e8c652ec847e4b007d1e09ab2778026a
    CRC32: b77722bf
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO20.6.txt (537 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 586901504 字节 (559.71 MB)
    修改日期: 2022-03-25 10:00
    MD5: be9a770bc29cc70d96f59b3d405005d1
    SHA1: a58da2eb3fd67d1a5124de0413aa1305261ccdc1
    SHA256: 9b3cc17a49237bb4a469539d7f2a501ba1dbdab226fea3204a3270c73186ad7c
    CRC32: 4e63e0c3
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.6RTE32.txt (573 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 589670400 字节 (562.35 MB)
    修改日期: 2022-03-25 09:54
    MD5: b16ff63bf36810b0a225478de133477f
    SHA1: 4edc42b98b2b315ce1c87e86bbb8a013273011c8
    SHA256: b0bd575c7775b6ff892ee79f652bbc9c1690069f504c8ebe2af69970fc407122
    CRC32: 5ee5a49f
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.6RTE64.txt (561 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 20.6 Readme
    January 2021
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO 19.1 includes the following new features:
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx EV-DO dropped support for all 32-bit Windows operating systems. RFmx EV-DO will not install or run on an unsupported OS. Refer to RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx EV-DO dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx EV-DO 20.6 to an unsupported OS. Additionally, after installing RFmx EV-DO 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. To add support for application software installed after installing RFmx EV-DO modify your RFmx EV-DO installation or launch the RFmx EV-DO installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx EV-DO
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx EV-DO using NI Package Manager. If you do not already have NI software installed, RFmx EV-DO installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Examples.
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx EV-DO known issues list online at RFmx EV-DO 20.6 Known Issues.
    You can access the RFmx EV-DO bug fix list online at RFmx EV-DO 20.6 Bug Fixes
    RFmx EV-DO will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2021 National Instruments. All rights reserved.
    375526M-01
    GMT+8, 2026-2-26 06:53
