查看: 1832|回复: 0
[NI软件产品] NI RFmx EV-DO 20.7 x64Win10 32/64bitEng 1xEV-DO蜂窝测试软件20.7
    昨天 09:54
  • 签到天数: 3808 天
     楼主| 发表于 2022-7-8 16:54:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2021/4/20
    包含的版本:20.7
    完整版校验和:
    文件大小: 869355520 字节 (829.08 MB)
    修改日期: 2022-03-25 09:46
    MD5: 253f8000a8a772f234e48d078153361b
    SHA1: 3954fa266cf65a1b70fed4161795496865074931
    SHA256: 91070a1364cf1f8738e11e841cb520cded6c5d53d4e642031b9240da28cda512
    CRC32: 8fe0dc23
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO20.7.0.txt (539 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 607631360 字节 (579.48 MB)
    修改日期: 2022-03-25 10:01
    MD5: d91ca09e4881aa7401bc694ba1e1a281
    SHA1: 3a457ead0808e9ac81c4b559f5890222b30ba8a8
    SHA256: b9303287520ee9d10970ce4248dc224907829e5218ac75ef7f8f57a1c02d5f5c
    CRC32: 559ec8e0
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.7.0RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 611340288 字节 (583.02 MB)
    修改日期: 2022-03-25 09:55
    MD5: 805a179140b95ac2f21396e358ba5e84
    SHA1: 2b0696ddf23096a582de4f39994f7d7e0b07a48e
    SHA256: 94a7e9916732f18f72e6e1f65278714c91f9cb92738a9f6c5b69bd28e170b44e
    CRC32: 23019146
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.7.0RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 20.7 Readme
    April 2021
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO 19.1 includes the following new features:
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 20.7 supports the following 64-bit operating systems:
    Note    RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 20.7 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 20.7 to an unsupported OS. Additionally, after installing RFmx EV-DO 20.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx EV-DO
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 20.7 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Examples.
    The following are the behavior changes in RFmx RFmx EV-DO 20.7 from RFmx RFmx EV-DO 20.6.
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx EV-DO known issues list online at RFmx EV-DO 20.7 Known Issues.
    You can access the RFmx EV-DO bug fix list online at RFmx EV-DO 20.7 Bug Fixes
    .Automating the Installation of NI Products
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375526N-01
    GMT+8, 2026-2-26 03:14
