查看: 1623|回复: 0
[NI软件产品] NI RFmx EV-DO 20.7.1 x64Win10 32/64bitEng 1xEV-DO蜂窝测试软件20.7.1
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2022-7-8 16:59:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2021/7/20
    包含的版本:20.7.1
    完整版校验和:
    文件大小: 869322752 字节 (829.05 MB)
    修改日期: 2022-03-25 09:47
    MD5: 9746b89d6567eebd88b35a30df9ac326
    SHA1: cfbce6d9a4ccf47dfde9eafcef076e77345e901d
    SHA256: 5cc0aea4a47917855970f999c9f0d05a05ac7ed0e210a873087db58f99d68a8f
    CRC32: 1bea903f
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO20.7.1.txt (539 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 607610880 字节 (579.46 MB)
    修改日期: 2022-03-25 10:02
    MD5: cbc01ba41e164a35f5c59bcd263ca138
    SHA1: 538804df96ee5e0d44cb63fd93d4fa8285ef0adc
    SHA256: bfaa9aeaa496d4f0c6849c0b442c3e8a9c4d84579db77dead6c50597bf4be41d
    CRC32: 2eec9a49
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.7.1RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 611330048 字节 (583.01 MB)
    修改日期: 2022-03-25 09:55
    MD5: 51697488e93d96e64d872bbea05e4c7e
    SHA1: c2bdae1ee936cecd69d2a2573c09d1e71bc0efa5
    SHA256: 7f51931519ef987c55949fa605d0a42435152151b64da224eed9a9f4ab221a46
    CRC32: 151cd70a
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.7.1RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 20.7.1 Readme
    July 2021
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO 19.1 includes the following new features:
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 20.7.1 to an unsupported OS. Additionally, after installing RFmx EV-DO 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx EV-DO
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Examples.
    The following are the behavior changes in RFmx RFmx EV-DO 20.7 from RFmx RFmx EV-DO 20.6.
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx EV-DO known issues list online at RFmx EV-DO 20.7.1 Known Issues.
    You can access the RFmx EV-DO bug fix list online at RFmx EV-DO 20.7.1 Bug Fixes
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375526P-01
    GMT+8, 2025-12-6 08:56
