查看: 1857|回复: 0
[NI软件产品] NI RFmx EV-DO 21.8.2 x64Win10 32/64bitEng 1xEV-DO蜂窝测试软件21.8.2
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2022-7-8 17:15:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2022/6/30
    包含的版本:21.8.2
    完整版校验和:
    文件大小: 814471168 字节 (776.74 MB)
    修改日期: 2022-06-30 09:47
    MD5: e61aced7631527c11a18f58e82cb71e5
    SHA1: 99d634e1cee8e027f131ac917dbe760e401a0f73
    SHA256: f782cbc51a6ecf6da85eafa774b758f318dea9237305c0540c50d71a7d641374
    CRC32: 0c9be559
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO21.8.2.txt (539 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 602230784 字节 (574.33 MB)
    修改日期: 2022-06-29 21:48
    MD5: 95079f45da9939e6f75b0bc2676c4d39
    SHA1: db7c7a7c0f075638e35d32ff4826e9ab4d8612ea
    SHA256: 6e0c946f360fa4c6973df0f6ebcbc9663f76fd00ef850381a99354c2872a5308
    CRC32: b4002d53
    NI官方下载和百度网盘下载地址:
    RFmx EVDO21.8.2RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 606828544 字节 (578.72 MB)
    MD5: 994f58788f32a6edaeaacdea35824a5b
    SHA1: 4901e2669712ac98d4285f53df1d6b1fa9d9cd84
    SHA256: ea6b8feb9a212d2a7b41259f47171c8c9e1ed1ab193bdb3d3006f931d3896a13
    CRC32: db540a64
    NI官方下载和百度网盘下载地址:
    RFmx EVDO21.8.2RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 21.8.2 Readme
    May 2022
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    • RFmx EV-DO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx EV-DO Manuals: New features, behavior changes, and other documentation
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 21.3 includes the following new feature:
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO 19.1 includes the following new feature:
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 21.8.2 to an unsupported OS. Additionally, after installing RFmx EV-DO 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx EV-DO
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » National Instruments » RFmx EV-DO » RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start » National Instruments » RFmx EV-DO » RFmx EV-DO Examples.
    The following are the behavior changes in RFmx EV-DO 20.7 from RFmx EV-DO 20.6.
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    375526V-01
    GMT+8, 2025-12-6 08:55
