查看: 1649|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2.3.1 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件2.3.1
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:03:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2017/10/16
    包含的版本:2.3.1
    Windows 10
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 664182744 字节 (633.41 MB)
    修改日期: 2022-03-25 22:16
    MD5: 4f62a8922229d178437c03db33fb737b
    SHA1: c79716894ef53c7e965205fb9deee70d08d43444
    SHA256: bcbeedb98c5a60ce84fa8f29266e0972d08211e2443604a81730d93647f3288b
    CRC32: 054fa301
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 2.3.1.txt (496 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 369532944 字节 (352.41 MB)
    MD5: acf69f7c29771f46b0ee89a1ba62eb57
    SHA1: 5ee932b8744fe03dcccbbe0b57289d6a5df8e98a
    SHA256: f73180338a52d77cab7523115b828456b9753e56f26561d517daaec2e12ca12c
    CRC32: 59351980
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.3.1RTE64.txt (508 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 372367352 字节 (355.12 MB)
    MD5: 98cf7384996111dc9268a912eb95cb8e
    SHA1: 8e22d33a11fb40b973fdb805bee1d28c6218afda
    SHA256: 4a81f98a163e4102dc0dc5ac58d399a5283a1a377b2e2d9f0b82f77f4101132a
    CRC32: c7bc6e52
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.3.1RTE32.txt (508 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 2.3.1 Readme
    October 2017
    This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx GSM
    NI-RFmx GSM 2.3 includes the following new features:
    NI-RFmx GSM 2.2 includes the following new features:
    • Support for I/Q gain imbalance for EDGE
    • Support for access burst in PVT
    • Support for constellation trace in ModAcc
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    NI-RFmx GSM 2.1 f4 includes the following bug fixes and updates:
    • Fixed an issue where NI-RFmx was crashing when the memory usage in a process increased beyond 2 GB.
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    • For the Analysis-Only mode, user needs to adjust the t0 value of the I/Q waveforms according to pre-trigger samples present in the waveform before passing the waveform to the Analyze (IQ) function.
    Caution  Before you install NI-RFmx GSM 2.3.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx GSM 2.3.1 supports the following operating systems:
    Note  NI-RFmx GSM 2.3.1 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 2.3.1 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    NI-RFmx GSM 2.3.1 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx GSM drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 2.3.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 2.3.1 to an unsupported OS. Additionally, after installing NI-RFmx GSM 2.3.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx GSM 2.3.1 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx GSM 2.3.1 installation, the following software is installed. To completely remove the NI-RFmx GSM 2.3.1 installation from your system, you must also remove the following package:
    • NI-RFmx GSM Runtime 2.3.1
    • NI-RFmx GSM Runtime 2.3.1 (64-bit)
    The following items are the behavior changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    • The alias 'default@GSM' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx GSM 2.3.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx GSM 2.3.1
    The following items are changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    654867Fixed an issue where the C functions and .NET methods used to configure the ORFS Custom Offset Frequency Array threw an error.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx GSM 2.3 from NI-RFmx GSM 2.2.
    The following items are changes in NI-RFmx GSM 2.2 from NI-RFmx GSM 2.1.
    560076Fixed an issue where a high phase error was observed in the initial few samples of the phase error trace for GMSK, with certain generation sources.
    © 2015–2017 National Instruments. All rights reserved.
    375557E-01
    GMT+8, 2026-1-28 10:53
