查看: 1528|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2.5 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件2.5
    昨天 08:48
  • 签到天数: 3722 天
    连续签到: 49 天
     楼主| 发表于 2022-7-12 16:10:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2018/7/3
    包含的版本:2.5
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 569159632 字节 (542.79 MB)
    修改日期: 2022-03-25 22:16
    MD5: 803a3d6b5102cf7a10058e9218c4d233
    SHA1: c7a6ed199e60b2043fa791504263ebd3128ac1a4
    SHA256: e1e65856a58c82b0d4f721f071115cdc62c3e538085350d915bb64347317bb9c
    CRC32: 01d94f89
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 2.5.txt (492 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 341467144 字节 (325.65 MB)
    MD5: 1baee99f2ad8ad78d0a5c2492dd7a23d
    SHA1: ef6635095baa89b0d78d6560c206d245027be4f9
    SHA256: 914b0117dfe441ff17ef857233545a8cc671cf4e9767d9e78737e55f511b0e06
    CRC32: 38aac119
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.5RTE64.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 348360688 字节 (332.22 MB)
    MD5: ad4781b8da09204887bfc1b79c0481cb
    SHA1: 47df3c77d213f01d1de2639611b2a9c2abba1c1f
    SHA256: 041532a9eca2de4840f6d0793d27e576ef235a79575731d24baedac9940d2822
    CRC32: 1a0f8f1b
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.5RTE32.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx GSM 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxGSM Commit API
    NI-RFmx GSM 2.3 includes the following new features:
    Caution  Before you install NI-RFmx GSM 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx GSM 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx GSM dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 2.5 to an unsupported OS. Additionally, after installing NI-RFmx GSM 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx GSM 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 2.5 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    The following items are the behavior changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    • The alias 'default@GSM' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx GSM 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx GSM 2.5
    The following items are changes in NI-RFmx GSM 2.4 from NI-RFmx GSM 2.3.1.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    654867Fixed an issue where the C functions and .NET methods used to configure the ORFS Custom Offset Frequency Array threw an error.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx GSM 2.3 from NI-RFmx GSM 2.2.
    © 2015–2018 National Instruments. All rights reserved.
    375557G-01
    GMT+8, 2025-11-25 02:24
