查看: 1703|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 3.0 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件3.0
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:14:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2019/1/17
    包含的版本:3.0
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 563879888 字节 (537.76 MB)
    修改日期: 2022-03-25 22:16
    MD5: 2dff50dbf4202fad5c9bca4f5333111a
    SHA1: 543fc31eeaf197fe763c28e8a9abe75b98f8f6bc
    SHA256: fe74912d3a8f1bbafa7215ca5f7f5da5f701171fdd0854bf591767410e09c2a9
    CRC32: 9a7469f6
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 3.0.txt (492 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 334188552 字节 (318.71 MB)
    MD5: 890dd6c9c626469205e2e936c686e876(重复一致)
    SHA1: 877ee572c8e7afd1df8bd3bc2ab96e8b680656aa
    SHA256: 96ac1cbef6c2a63c456cb58405ea0da8015d1a84b283f0f1d4219ab7041874c2
    CRC32: 65c15bb5
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 3.0RTE64.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 340783088 字节 (325.00 MB)
    MD5: b6be4e90037d5a19698f3db5c420dedc
    SHA1: b9d0d5ad3f9120bb14e26df9e85a13d81cbd4bae
    SHA256: ba92af68706ea2cf154c838b1e5a987dac1fe5d2fe9634b07bef68716c6a9868
    CRC32: c8c4de30
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 3.0RTE32.txt (506 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx GSM 3.0 includes the following new features:
    • Support for NI PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for PvT measurement across slots of varying powers
    NI-RFmx GSM 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxGSM Commit API
    NI-RFmx GSM 2.3 includes the following new features:
    Caution  Before you install NI-RFmx GSM 3.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx GSM 3.0 supports the following operating systems:
    Note  In 2016, NI-RFmx GSM dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 3.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 3.0 to an unsupported OS. Additionally, after installing NI-RFmx GSM 3.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx GSM 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 3.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    The following items are the behavior changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    • The alias 'default@GSM' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    No known issues.
    The following items are changes in NI-RFmxGSM 3.0 from NI-RFmx GSM 2.5
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the NI-PXIe-5840.
    704716Fixed an issue where the GMSK/ EDGE PVT mask was incorrect for GSM 400, GSM 700, GSM 850 and GSM 900 bands.
    The following items are changes in NI-RFmx GSM 2.4 from NI-RFmx GSM 2.3.1.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    654867Fixed an issue where the C functions and .NET methods used to configure the ORFS Custom Offset Frequency Array threw an error.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx GSM 2.3 from NI-RFmx GSM 2.2.
    © 2015–2019 National Instruments. All rights reserved.
    375557H-01
    GMT+8, 2026-1-28 10:54
