查看: 1410|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 19.1 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件19.1
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:20:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2019/10/17
    包含的版本:19.1
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 874780672 字节 (834.26 MB)
    修改日期: 2022-03-25 22:15
    MD5: 39cd5998b2fdef76d19efa5acd5522ac
    SHA1: 72879b94b7c763be17ebdf4f21a9eaf7e07e1706
    SHA256: 799119879ffa01c0ef3ebf3a00e364837c362589662519e8ca005850915bfbb4
    CRC32: c909009b
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 19.1.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 551956480 字节 (526.39 MB)
    MD5: 6e0385d481291082f511495760e80b8b
    SHA1: a4c42414c850cdb0cc1fbba9a0ca4a1b603225fd
    SHA256: 50c22cc95f8ab56e625f6a656f3069f0fdb05f18c9f1b4980790bfd0ca58d02f
    CRC32: 6f1f308c
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 19.1RTE64.txt (538 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 558440448 字节 (532.57 MB)
    MD5: 4401da7c2617356b6df5290e251db23d
    SHA1: c71d3fd8753e038e60e5266ef7fcf1e12fbe6dd3
    SHA256: 3cd4de92fcf0fc2d1ca85f5944d469ac34db4cb1ac06f9cafaab299229385355
    CRC32: e7095704
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 19.1RTE32.txt (546 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 19.1 Readme
    October 2019
    This file contains important information about the RFmx GSM, including system requirements and installation instructions.
    RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 19.1 includes the following new features:
    • Addition of RFmx GSM Soft Front Panel with debug support
    • Support for PXIe-5841
    • Support for 95 th percentile phase error in GSM PFER measurement
    • Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
    RFmx GSM 19.0 includes the following new features:
    RFmx GSM 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for PvT measurement across slots of varying powers
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx GSM has the following requirements:
    RFmx GSM 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx GSM dropped support for all 32-bit Windows operating systems. RFmx GSM will not install or run on an unsupported OS. Refer to RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx GSM. To add support for application software installed after installing RFmx GSM modify your RFmx GSM installation or launch the RFmx GSM installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx GSM using NI Package Manager. If you do not already have NI software installed, RFmx GSM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx GSM» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the software and documentation known issues list online. Refer to the RFmx GSM Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx GSM . This is not an exhaustive list of issues fixed in the current version of the RFmx GSM . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ API when performing a composite measurement with different averaging count for each measurement
    The following items are changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    237507Fixed an issue where querying ModAcc Results Detected TSC property for a slot index other than 0 resulted in an error.
    237509Fixed an issue where querying the PVT Results properties by specifying result name in selector string resulted in an error.
    The following items are changes in RFmx GSM 3.0 from RFmx GSM 2.5
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx GSM will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2015–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    375557K-01
    GMT+8, 2026-1-28 10:55
