查看: 1561|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 20.6 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件20.6
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:26:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2021/1/20
    包含的版本:20.6
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 853172224 字节 (813.65 MB)
    修改日期: 2022-03-25 10:09
    MD5: be1bac0060cbd4ba9550867774a82e1d
    SHA1: 17572e16e6f4c05cf609917e17d6244bc779304a
    SHA256: 7fde32415230b48ca0e35e915fbffec6fd1b583cc6006538c4f782593e31cf19
    CRC32: f9400ddf
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 20.6.txt (539 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 574504960 字节 (547.89 MB)
    修改日期: 2022-03-25 10:39
    MD5: 2be390fb9a6200685483161970e1b072
    SHA1: f6964badf75780f44a856a36fdc0bc79750e8a7f
    SHA256: 8c08a37ce0c4452e996ba203b824baf0d8fea13d642994c568426e85be2d8715
    CRC32: ba8d90c5
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.6RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 571844608 字节 (545.35 MB)
    修改日期: 2022-03-25 10:56
    MD5: 5c2e26e709f7c437354944d127c0b60e
    SHA1: ecf03e1eab4deee17e14599d4b33701ff937ac6f
    SHA256: 62ee77d48378627f2ac49976ad6657dd0904862ed02d68b57300603ee8f21a08
    CRC32: a92a90a6
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.6RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 20.6 Readme
    January 2021
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 20.0 includes the following new features:
    RFmx GSM 19.1 includes the following new features:
    • Addition of RFmx GSM Soft Front Panel with debug support
    • Support for 95 th percentile phase error in GSM PFER measurement
    • Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
    RFmx GSM 19.0 includes the following new features:
    RFmx GSM 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for PvT measurement across slots of varying powers
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx GSM has the following requirements:
    RFmx GSM 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx GSM dropped support for all 32-bit Windows operating systems. RFmx GSM will not install or run on an unsupported OS. Refer to RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx GSM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx GSM 20.6 to an unsupported OS. Additionally, after installing RFmx GSM 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. To add support for application software installed after installing RFmx GSM modify your RFmx GSM installation or launch the RFmx GSM installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx GSM using NI Package Manager. If you do not already have NI software installed, RFmx GSM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx GSM known issues list online at RFmx GSM 20.6 Known Issues.
    You can access the RFmx GSM bug fix list online at RFmx GSM 20.6 Bug Fixes.
    RFmx GSM will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2021 National Instruments. All rights reserved.
    375557M-01
    GMT+8, 2026-1-28 10:52
