查看: 1584|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 20.7.1 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件20.7.1
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:33:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2021/7/20
    包含的版本:20.7.1
    完整版校验和:
    文件大小: 932024320 字节 (888.85 MB)
    修改日期: 2022-03-25 10:13
    MD5: 99e636b51f9c5e854ddb4f5b517c9ab5
    SHA1: 88d983ca8c1e6059f664a65d6153ea5b87781fcf
    SHA256: 85ed34f15e5d580559b0d0cad45759f5183c549e71e653d35193e16a8cf0a34b
    CRC32: 43007af9
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 20.7.1.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 596176896 字节 (568.56 MB)
    修改日期: 2022-03-25 10:42
    MD5: 4ec11247121523f08bcfba0c84c2aa8c
    SHA1: 97d2ba345105ea1329fc72f6863d01d42463c657
    SHA256: 942f6d005005a88e14f5ed47e25438d2eb0e7f66843d566659ce9080cd32373d
    CRC32: 9e7ca444
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.7.1RTE64.txt (565 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 592574464 字节 (565.12 MB)
    修改日期: 2022-03-25 10:59
    MD5: 868d875d233b8564eb2bb2a8dece2145
    SHA1: 4a61adb207ba226e91fa481bbe5adc0ba3f6b4bc
    SHA256: d1cc7560c2aa250e89597aafb256934122c842bb1869b9dc8b6e04f78ec28d86
    CRC32: bee00d97
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.7.1RTE32.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 20.7.1 Readme
    July 2021
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 20.7 includes the following new features:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    RFmx GSM 19.1 includes the following new features:
    • Addition of RFmx GSM Soft Front Panel with debug support
    • Support for 95 th percentile phase error in GSM PFER measurement
    • Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
    RFmx GSM 19.0 includes the following new features:
    RFmx GSM 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for PvT measurement across slots of varying powers
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx GSM has the following requirements:
    RFmx GSM 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 20.7.1 to an unsupported OS. Additionally, after installing RFmx GSM 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx GSM known issues list online at RFmx GSM 20.7 Known Issues.
    You can access the RFmx GSM bug fix list online at RFmx GSM 20.7 Bug Fixes.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375557P-01
    GMT+8, 2026-1-28 10:54
