查看: 1607|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 21.5 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件21.5
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:43:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2022/1/27
    包含的版本:21.5
    完整版校验和:
    文件大小: 1025069056 字节 (977.58 MB)
    修改日期: 2022-03-25 10:17
    MD5: f0193a2c3028d4517668396d1b4ddfc1
    SHA1: e22e94f8dbe6d5f9d32e8479181fe2d4679ce463
    SHA256: b0190ca5490b7c1ada210efc95712e46ac2219e4966acfd271a504c7454bcf61
    CRC32: 7715024d
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 21.5.txt (540 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 584069120 字节 (557.01 MB)
    修改日期: 2022-03-25 10:47
    MD5: 4a16bcafbafb858dfa910928c202d6a4
    SHA1: f44fd3813cf425ae8fba87753c24cc9d6ba4290f
    SHA256: 1b2bcffd5b2187fe1557035f8e3664adce869801d55674838ce40bb560719837
    CRC32: 31069304
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.5RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 580644864 字节 (553.75 MB)
    修改日期: 2022-03-25 11:02
    MD5: ae20c997b9f13c4f81236db46a606d91
    SHA1: e134db18febb3599746f4e2f94b7043b64747aca
    SHA256: ae2d85ba2e2437cdd242572c0cfe9d26cdd73dbb69d7b13106e2d941c4af56e8
    CRC32: a7736c34
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.5RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 21.5 Readme
    January 2022
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 21.3 includes the following new features:
    RFmx GSM 20.7 includes the following new features:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx GSM has the following requirements:
    RFmx GSM 21.5 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 21.5 to an unsupported OS. Additionally, after installing RFmx GSM 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » National Instruments » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 21.5 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    375557T-01
    GMT+8, 2026-1-28 10:54
