查看: 1752|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 21.8.1 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件21.8.1
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
     楼主| 发表于 2022-7-12 16:50:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2022/4/30
    包含的版本:21.8.1
    完整版校验和:
    文件大小: 1034729472 字节 (986.79 MB)
    修改日期: 2022-04-30 01:45
    MD5: f9cf01aa93f6612440470b7456bb2eb9(官方正确)
    SHA1: 86df3182966a5c76b7689b4e8bb00a6018650026
    SHA256: 81b6494e445bed9a45ba8cf38ff155a4ace2d479c48afbc99c701ae8e2d48765
    CRC32: 1316aabe
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 21.8.1.txt (571 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 591460352 字节 (564.06 MB)
    MD5: 0a4b7b98334c3c3c105d94322af8a558(官方正确)
    SHA1: 6f07d2c21a8583657b2443d62a920716d4bdad8f
    SHA256: 9c8d15a481a0c459ea6b97ed004c9d444bf744a5cafb079c4f97addc87348e2a
    CRC32: 8a1d77e9
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.8.1RTE64.txt (594 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 587055104 字节 (559.86 MB)
    MD5: b7d720ea7d98d80db125e90b41582963(官方正确)
    SHA1: ae9c87939c145c5e7181ed0fdb4c91e5eb1f8d4d
    SHA256: 24f1303142491db562c53be110178fc9cf6721a43bc5a2ded3a328a9b42aad15
    CRC32: 6aa3b939
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.8.1RTE32.txt (606 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 21.3 includes the following new feature:
    RFmx GSM 20.7 includes the following new feature:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    RFmx GSM has the following requirements:
    RFmx GSM 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 21.8.1 to an unsupported OS. Additionally, after installing RFmx GSM 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    ItemInstalled Location
    Import Library files
    Select Start » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    375557V-01
    GMT+8, 2026-1-28 10:54
