查看: 1775|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 2.5 Win32/64Eng LTE/LTE演进蜂窝测试软件2.5
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 11:29:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2018/7/3
    包含的版本:2.5
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 732717008 字节 (698.77 MB)
    修改日期: 2022-03-25 22:17
    MD5: 679bc6ae7a75e95b311f30f720942d0b
    SHA1: daa313521d788b1bd56aebd7f62e0905fa10f37e
    SHA256: b171472995848441dbc5339efdcb1cab0420ba0990acd5f00a989a1fa44fe1fc
    CRC32: 381b24d8
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE2.5.txt (498 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 360349704 字节 (343.66 MB)
    MD5: 315a9e4b9b3455c1d8e5ba4c22167b45
    SHA1: 4ff47c5d7bb5893e3e6a2eec2423f6298a19b308
    SHA256: bfb6e3faa14ffdd31e6028b3bc46954cedece107ffa99ca8568941482d416ac5
    CRC32: 4473ffe2
    NI官方下载和百度网盘下载地址:
    RFmx LTE2.5RTE64.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 366944240 字节 (349.95 MB)
    MD5: 612b75e43653e7d0151bb2b88f905a72
    SHA1: dcb0f9992ce2eff47a616d85d7ac7f04a9cbefde
    SHA256: 7df987cff8d31747967a458daa9675db4a620751fe1f9598afa4d13132b4c8c7
    CRC32: c06f2d9a
    NI官方下载和百度网盘下载地址:
    RFmx LTE2.5RTE32.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx LTE 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx LTE and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx LTE 2.5 includes the following new features:
    • Addition of ModAcc, ACP, SEM, CHP, and OBW measurements for NB-IoT
    • Addition of EUTRA offset channel definition for ACP measurement
    • Addition of IBE mask for UEs supporting 3GPP Release 11 and higher
    • Addition of gain imbalance and quadrature skew measurements for downlink LAA
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for 3GPP Release 14 NB-IoT, includes single tone and multitone (3, 6, and 12 tones), Format 1 and Format 2, 15 kHz, and 3.75 kHz configurations
    • Support for demodulating Cat-M1 waveforms with frequency hopping and guard symbols
    • Support for configurable number of offsets in downlink ACP
    • Support for NS_35 (Band 71) and NS_27 additional spectral emission mask requirements
    • Support for querying configuration attributes without calling RFmxLTE Commit API
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for monitoring a RFmx application in NI-RFmx Soft Front Panel
    NI-RFmx LTE 2.4 includes the following new features:
    • Addition of Mi configuration, which determines the number of PHICH groups in each downlink subframe in case of TDD
    • Addition of special subframe configuration 9 in ModAcc measurement
    • Support for LTE-A pro licensed assisted access in ModAcc measurement for both uplink and downlink
    • Support for auto-detecting downlink PDSCH channel parameters (ModScheme, RB Allocations, and Relative Channel Power)
    • Support for auto-detecting control channel powers for PSS, SSS, PBCH, PCFICH, and PDCCH
    • Support for auto-detecting control format indicator (CFI) of the PCFICH Channel
    • Support for 1024 QAM along with auto-detection in uplink and downlink
    • Support for filtering of band emissions for a single carrier ModAcc analysis on uplink
    • Support for extended cyclic prefix on uplink
    • Support for PUSCH in the presence of PUCCH
    NI-RFmx LTE 2.3.1 includes the following new feature:
    • Addition of NI-RFmx LTE Soft Front Panel (SFP 64-bit) with debug support
    NI-RFmx LTE 2.3 includes the following new features:
    • Addition of Slot Phase measurement for uplink
    • Addition of Slot Power measurement for uplink
    • Addition of "General CA Class B" and "CA_NC_NS_01" masks for uplink in SEM measurement
    • Addition of a sequential FFT measurement method in ACP measurement
    • Addition of downlink support in ModAcc, ACP, SEM, CHP and OBW measurements
    • Support for SRS including UpPTS for uplink in ModAcc measurement
    • Support for DMRS with OCC (Orthogonal Cover Code) for uplink in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    Installation InstructionsCaution  Before you install NI-RFmx LTE 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers require that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx LTE 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx LTE dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx LTE 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx LTE 2.5 to an unsupported OS. Additionally, after installing NI-RFmx LTE 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx LTE 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx LTE. To add support for ADEs installed after installing NI-RFmx LTE, modify your NI-RFmx LTE installation or launch the NI-RFmx LTE installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx LTE does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\LTE\Examples
    Examples\LabVIEW \examples\RFmx\LTE
    In 32-bit OS, select Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Measurement Interactive Panel to launch the NI-RFmx LTE Measurement Interactive Panel (32-bit).
    Select Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Note  NI-RFmx Soft Front Panel does not support the following LTE measurements:
    • SlotPhase Measurement
    • SlotPower Measurement
    However, these measurements are supported in NI-RFmx LTE Measurement Interactive Panel.
    Documentation for NI-RFmx LTE is located at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx LTE HelpHTML/Windows HelpInformation about NI-RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx LTE
    • A complete reference for all NI-RFmx LTE programming VIs
    NI-RFmx LTE 2.5 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    NI-RFmx LTE palette VIs are available from the Functions»Measurement I/O»NI-RFmx»LTE palette.
    You can access all the installed NI-RFmx LTE examples at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Examples.
    The following items are the behavior changes in NI-RFmx LTE 2.5 from NI-RFmx LTE 2.4.
    • Spectral flatness range 1 and range 2 limits are changed to use test requirements.
    • Dropped support for NI-RFmx LTE Measurement Interactive Panel 64-bit.
    The following items are the behavior changes in NI-RFmx LTE 2.3.1 from NI-RFmx LTE 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@LTE' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx LTE 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx LTE 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx LTE. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx LTE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx LTE 2.4 from NI-RFmx LTE 2.3.1.
    665930Fixed an issue where in-band emission (IBE) test requirement table for release 8-10 UEs is made 3GPP Specification release 14 compliant.
    664616Fixed an issue where LTE uplink equalizer coefficients are calculated using the least square method as per section E.3.3 of 3GPP TS 36.521-1 specification.
    655346Fixed an issue where DMRS auto-detect was internally getting enabled when hopping is enabled.
    654382Fixed an issue with using special subframes in case of DL TDD for channel estimation.
    630327Fixed an issue with computing channel estimation and CFO for the slots under measurement to improve standard deviation of EVM.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod, resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx LTE 2.3.1 from NI-RFmx LTE 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    655756Fixed an issue where values were swapped on configuring the SEM Offset Start Freq property higher than the SEM Offset Start Freq property.
    646771Fixed an issue with configuring SEM offsets, other than offset0, when the Mask Type is Custom.
    The following items are changes in NI-RFmx LTE 2.3 from NI-RFmx LTE 2.2.
    622407Fixed an issue with configuring SEM custom offsets with a named signal.
    625184Fixed an issue with retrieving the value of the SEM Offset RBW property when the mask type is Custom.
    623095Fixed an issue with the Analysis-Only mode, ModAcc measurement does not require configuration of pre-trigger delay in t0 value of the I/Q waveforms.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2015–2018 National Instruments. All rights reserved.
    375558G-01
    GMT+8, 2026-2-3 06:35
