查看: 1779|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 3.0 Win32/64Eng LTE/LTE演进蜂窝测试软件3.0
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 11:59:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2019/1/17
    包含的版本:3.0
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 770334672 字节 (734.65 MB)
    修改日期: 2022-03-25 22:17
    MD5: a204fe064a8ce7445ad126887b88a912
    SHA1: ace37f2c52676ecf2049b93039f1b1681895a46a
    SHA256: bd6451f1bed0d80e5095c33ebb14524aaa080a5f57be750284c32c74c0da831f
    CRC32: a751998c
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE3.0.txt (498 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 358129672 字节 (341.54 MB)
    MD5: bdb6ecbd80573d2c2c667faeaa59948c
    SHA1: 3f11d2d0e2ae6d9ae541877f116a6654388f11d0
    SHA256: 0c1024128250deab1d28fe3d5547d4b9b79fc95991097272bfedf59e309aab88
    CRC32: 082a7940
    NI官方下载和百度网盘下载地址:
    RFmx LTE3.0RTE64.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 364392432 字节 (347.51 MB)
    MD5: a1e1cb27eadee6254861947aa9a55e08
    SHA1: 346a6c01754f0ca0a0592899c45a303e7b8705e9
    SHA256: d30a314fee4101e957ab2ff1470da0e30ac75bbda8860279a21c0088605446ee
    CRC32: 851e88c9
    NI官方下载和百度网盘下载地址:
    RFmx LTE3.0RTE32.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx LTE 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx LTE and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx LTE 3.0 includes the following new features:
    • Support for NI PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for Auto Level in RFmx Soft Front Panel
    • NS_04 additional SEM requirements according to Table 6.6.2.2.3.2-3 of the 3GPP TS 36.521-1 specification (Release 12 and later)
    NI-RFmx LTE 2.5 includes the following new features:
    • Addition of ModAcc, ACP, SEM, CHP, and OBW measurements for NB-IoT
    • Addition of EUTRA offset channel definition for ACP measurement
    • Addition of IBE mask for UEs supporting 3GPP Release 11 and higher
    • Addition of gain imbalance and quadrature skew measurements for downlink LAA
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for 3GPP Release 14 NB-IoT, includes single tone and multitone (3, 6, and 12 tones), Format 1 and Format 2, 15 kHz, and 3.75 kHz configurations
    • Support for demodulating Cat-M1 waveforms with frequency hopping and guard symbols
    • Support for configurable number of offsets in downlink ACP
    • Support for NS_35 (Band 71) and NS_27 additional spectral emission mask requirements
    • Support for querying configuration attributes without calling RFmxLTE Commit API
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for monitoring a RFmx application in NI-RFmx Soft Front Panel
    NI-RFmx LTE 2.4 includes the following new features:
    • Addition of Mi configuration, which determines the number of PHICH groups in each downlink subframe in case of TDD
    • Addition of special subframe configuration 9 in ModAcc measurement
    • Support for LTE-A pro licensed assisted access in ModAcc measurement for both uplink and downlink
    • Support for auto-detecting downlink PDSCH channel parameters (ModScheme, RB Allocations, and Relative Channel Power)
    • Support for auto-detecting control channel powers for PSS, SSS, PBCH, PCFICH, and PDCCH
    • Support for auto-detecting control format indicator (CFI) of the PCFICH Channel
    • Support for 1024 QAM along with auto-detection in uplink and downlink
    • Support for filtering of band emissions for a single carrier ModAcc analysis on uplink
    • Support for extended cyclic prefix on uplink
    • Support for PUSCH in the presence of PUCCH
    NI-RFmx LTE 2.3.1 includes the following new feature:
    • Addition of NI-RFmx LTE Soft Front Panel (SFP 64-bit) with debug support
    NI-RFmx LTE 2.3 includes the following new features:
    • Addition of Slot Phase measurement for uplink
    • Addition of Slot Power measurement for uplink
    • Addition of "General CA Class B" and "CA_NC_NS_01" masks for uplink in SEM measurement
    • Addition of a sequential FFT measurement method in ACP measurement
    • Addition of downlink support in ModAcc, ACP, SEM, CHP and OBW measurements
    • Support for SRS including UpPTS for uplink in ModAcc measurement
    • Support for DMRS with OCC (Orthogonal Cover Code) for uplink in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    Installation InstructionsCaution  Before you install NI-RFmx LTE 3.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers require that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx LTE 3.0 supports the following operating systems:
    Note  In 2016, NI-RFmx LTE dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx LTE 3.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx LTE 3.0 to an unsupported OS. Additionally, after installing NI-RFmx LTE 3.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx LTE 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx LTE. To add support for ADEs installed after installing NI-RFmx LTE, modify your NI-RFmx LTE installation or launch the NI-RFmx LTE installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx LTE does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\LTE\Examples
    Examples\LabVIEW \examples\RFmx\LTE
    In 32-bit OS, select Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Measurement Interactive Panel to launch the NI-RFmx LTE Measurement Interactive Panel (32-bit).
    Select Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Note  NI-RFmx Soft Front Panel does not support the following LTE measurements:
    • SlotPhase Measurement
    • SlotPower Measurement
    However, these measurements are supported in NI-RFmx LTE Measurement Interactive Panel.
    Documentation for NI-RFmx LTE is located at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx LTE HelpHTML/Windows HelpInformation about NI-RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx LTE
    • A complete reference for all NI-RFmx LTE programming VIs
    NI-RFmx LTE 3.0 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    NI-RFmx LTE palette VIs are available from the Functions»Measurement I/O»NI-RFmx»LTE palette.
    You can access all the installed NI-RFmx LTE examples at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Examples.
    The following items are the behavior changes in NI-RFmx LTE 3.0 from NI-RFmx LTE 2.5.
    • ModAcc synchronization algorithm assumes that all component carriers are time aligned.
    The following items are the behavior changes in NI-RFmx LTE 2.5 from NI-RFmx LTE 2.4.
    • Spectral flatness range 1 and range 2 limits are changed to use test requirements.
    • Dropped support for NI-RFmx LTE Measurement Interactive Panel 64-bit.
    The following items are the behavior changes in NI-RFmx LTE 2.3.1 from NI-RFmx LTE 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@LTE' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    No known issues.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx LTE. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx LTE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx LTE 3.0 from NI-RFmx LTE 2.5.
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the NI-PXIe-5840.
    707274Fixed an issue where the ModAcc RMS phase error per symbol trace was incorrect.
    719418Fixed an issue where the sweep time for the NBIoT 3.75kHz subcarrier spacing was incorrect in LTE ACP measurement when the Auto Sweep time was set to True.
    The following items are changes in NI-RFmx LTE 2.4 from NI-RFmx LTE 2.3.1.
    665930Fixed an issue where in-band emission (IBE) test requirement table for release 8-10 UEs is made 3GPP Specification release 14 compliant.
    664616Fixed an issue where LTE uplink equalizer coefficients are calculated using the least square method as per section E.3.3 of 3GPP TS 36.521-1 specification.
    655346Fixed an issue where DMRS auto-detect was internally getting enabled when hopping is enabled.
    654382Fixed an issue with using special subframes in case of DL TDD for channel estimation.
    630327Fixed an issue with computing channel estimation and CFO for the slots under measurement to improve standard deviation of EVM.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod, resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx LTE 2.3.1 from NI-RFmx LTE 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    655756Fixed an issue where values were swapped on configuring the SEM Offset Start Freq property higher than the SEM Offset Start Freq property.
    646771Fixed an issue with configuring SEM offsets, other than offset0, when the Mask Type is Custom.
    The following items are changes in NI-RFmx LTE 2.3 from NI-RFmx LTE 2.2.
    622407Fixed an issue with configuring SEM custom offsets with a named signal.
    625184Fixed an issue with retrieving the value of the SEM Offset RBW property when the mask type is Custom.
    623095Fixed an issue with the Analysis-Only mode, ModAcc measurement does not require configuration of pre-trigger delay in t0 value of the I/Q waveforms.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2015–2019 National Instruments. All rights reserved.
    375558H-01
    GMT+8, 2026-2-3 06:35
