查看: 1927|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 19.1 Win32/64Eng LTE/LTE演进蜂窝测试软件19.1
    4 小时前
  • 签到天数: 3837 天
    连续签到: 30 天
     楼主| 发表于 2022-7-13 12:11:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2019/10/17
    包含的版本:19.1
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 652749315 字节 (622.51 MB)
    修改日期: 2022-03-25 22:16
    MD5: f6b24492d1ac01846360dace85fca744
    SHA1: e8f61e649642d7279a7202acb6436881097e5963
    SHA256: 67c24176015de17edf8b0237afa41c9fec334c3b9eb3fea8de88a28bcee291d0
    CRC32: 8677784e
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE19.1.txt (528 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 158592000 字节 (151.25 MB)
    MD5: 397b7873661964a843588fb75f8e628d
    SHA1: 7f8d3d06b76281031248f348255b4f56717890c3
    SHA256: bca597d7066d90f2eeab32dfa8e50b11538ae3fa5796066b88b7cd5261dc454e
    CRC32: 6a1e6981
    NI官方下载和百度网盘下载地址:
    RFmx LTE19.1RTE64.txt (544 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 583206912 字节 (556.19 MB)
    MD5: a157315a68a5ad8ed9df024567ee4491
    SHA1: 3ab054274ed481f7392140cb420a4e156cc2195e
    SHA256: f07531f94a1563d6ff0d077775c43031e9bd35306c0d542eee7e2d46e7e757d1
    CRC32: 2cb20218
    NI官方下载和百度网盘下载地址:
    RFmx LTE19.1RTE32.txt (552 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 19.1 Readme
    October 2019
    This file contains important information about the RFmx LTE, including system requirements and installation instructions.
    RFmx LTE Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx LTE 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    • Support for LTE-V2X or sidelink. Supported measurements are ModAcc, ACP, SEM, CHP, and OBW
    RFmx LTE 19.0 includes the following new features:
    • Support for PXIe-5830
    • Cat-M2 Release 14 Uplink Support
    RFmx LTE 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    • Support for Auto Level in RFmx Soft Front Panel
    • NS_04 additional SEM requirements according to Table 6.6.2.2.3.2-3 of the 3GPP TS 36.521-1 specification (Release 12 and later)
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx LTE has the following requirements:
    RFmx LTE 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx LTE dropped support for all 32-bit Windows operating systems. RFmx LTE will not install or run on an unsupported OS. Refer to RFmx LTE Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx LTE supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx LTE. To add support for application software installed after installing RFmx LTE modify your RFmx LTE installation or launch the RFmx LTE installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx LTE
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019
    If you are using the RFmx LTE .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx LTE .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx LTE using NI Package Manager. If you do not already have NI software installed, RFmx LTE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.LteMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx LTE» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start»All Programs»National Instruments»RFmx LTE»RFmx LTE Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start»All Programs»National Instruments»RFmx LTE»RFmx LTE Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx LTE 19.1 from RFmx LTE 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxLTE Analyze (IQ) and RFmxLTE Analyze (Spectrum) APIs. Use RFmxLTE Analyze (IQ, 1 Wfm) and RFmxLTE Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx LTE 19.0 from RFmx LTE 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    The following items are the behavior changes in RFmx LTE 3.0 from RFmx LTE 2.5.
    • ModAcc synchronization algorithm assumes that all component carriers are time aligned.
    You can access the software and documentation known issues list online. Refer to the RFmx LTE Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx LTE . This is not an exhaustive list of issues fixed in the current version of the RFmx LTE . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx LTE 19.1 from RFmx LTE 19.0
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement
    The following items are changes in RFmx LTE 3.0 from RFmx LTE 2.5.
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    243062Fixed an issue where the ModAcc RMS phase error per symbol trace was incorrect.
    243068Fixed an issue where the sweep time for the NBIoT 3.75kHz subcarrier spacing was incorrect in LTE ACP measurement when the Auto Sweep time was set to True .
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx LTE will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2015–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    375558K-01
    GMT+8, 2026-3-26 12:31
