查看: 1899|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 20.7 x64Win10 32/64bitEng LTE/LTE演进蜂窝测试软件20.7
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 12:25:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2021/4/20
    包含的版本:20.7
    完整版校验和:
    文件大小: 1026199552 字节 (978.66 MB)
    修改日期: 2022-03-25 11:16
    MD5: 06919252a6374a4ede79c5061e22b70c
    SHA1: df05b222518d6616a09392dedf77bf99d7066c79
    SHA256: 5bb89a51cee9e807016725c3d2161faf629a58efe0dcfa9d3df8b979aa78d682
    CRC32: 14b5504e
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE20.7.0.txt (548 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 621735936 字节 (592.93 MB)
    修改日期: 2022-03-25 11:38
    MD5: 1041ffa840f923802f1059e5dc824fbe
    SHA1: fdae00ec27dfd0677ee485829fcfb84776a107c7
    SHA256: 8d3c621c6b1b74f274bef9bec18345059226565005be263ef448fee6df298366
    CRC32: a6faa8a0
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.7.0RTE64.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 617859072 字节 (589.24 MB)
    修改日期: 2022-03-25 11:52
    MD5: 036f9d5a7b3c0e18a867ca9a6e3ee2f1
    SHA1: 28069f02c0350488df98826bc0933d9509d56700
    SHA256: 529de8a4e4a4ed0aa82e54b5dad4ff6f949faa892939f8ff28993d1f09adc45b
    CRC32: 7cb12514
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.7.0RTE32.txt (583 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 20.7 Readme
    April 2021
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 20.7 includes the following new features:
    • Support for IQ impairment compensation in uplink
    • Support for Time Alignment Error (TAE) measurement in downlink
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx LTE 20.0 includes the following new features:
    • Support for TM 2b and TM 3.1b downlink test Models
    • Support for demodulation of PSSCH in the presence of PSCCH for LTE-V2X
    • Addition of spectrum emission mask for CA Bandwidth Class B
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx LTE 20.7 supports the following 64-bit operating systems:
    Note    RFmx LTE no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx LTE 20.7 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx LTE 20.7 to an unsupported OS. Additionally, after installing RFmx LTE 20.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx LTE supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx LTE. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx LTE
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
      • LTE : This will enable analysis of FDD and TDD signals with standard-compliant physical layer measurements such as Error Vector Magnitude (EVM), Adjacent Channel Leakage Ratio (ACLR), Spectrum Emission Mask (SEM), Channel Power (CHP), Occupied Bandwidth (OBW), Power Versus Time (PVT), SlotPhase, and SlotPower measurements.
      • LTE-Advanced : This will enable analysis of LTE Advanced and LTE Advanced Pro features such as Carrier Aggregation, Higher Modulation Schemes, License Assisted Access (LAA) with standard-compliant physical layer measurements such as Error Vector Magnitude (EVM), Adjacent Channel Leakage Ratio (ACLR), Spectrum Emission Mask (SEM), and more
      • NB-IoT/eMTC : This will enable analysis of LTE Cat-NB1/NB2 and LTE Cat-M1/M2 Uplink signals with standard-compliant physical layer measurements such as Modulation Accuracy (ModAcc), Adjacent Channel Leakage Ratio (ACLR), Spectrum Emission Mask (SEM), and more.
      • LTE-V2X : This will enable analysis of sidelink PC5 signals with standard-compliant physical layer measurements such as Modulation Accuracy (ModAcc), Adjacent Channel Leakage Ratio (ACLR), Spectrum Emission Mask (SEM), and more.
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx LTE » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » All Programs » National Instruments » RFmx LTE » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 20.7 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » All Programs » National Instruments » RFmx LTE » RFmx LTE Examples.
    The following items are the behavior changes in RFmx LTE 20.7 from RFmx LTE 19.1
    The following items are behavior changes in RFmx LTE 19.1 from RFmx LTE 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxLTE Analyze (IQ) and RFmxLTE Analyze (Spectrum) APIs. Use RFmxLTE Analyze (IQ, 1 Wfm) and RFmxLTE Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx LTE 19.0 from RFmx LTE 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx LTE known issues list online at RFmx LTE 20.7 Known Issues.
    You can access the RFmx LTE bug fix list online at RFmx LTE 20.7 Bug Fixes. This list describes a subset of issues fixed in the RFmx LTE. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375558N-01
    GMT+8, 2026-2-3 06:37
