查看: 1916|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 21.3 x64Win10 32/64bitEng LTE/LTE演进蜂窝测试软件21.3
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 12:30:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2021/10/22
    包含的版本:21.3
    完整版校验和:
    文件大小: 1163110400 字节 (1.08 GB)
    修改日期: 2022-03-25 11:21
    MD5: d939adf2786c9ce316224c8d6c82c716
    SHA1: e62a1ef84de8809c39bab4cbf02e236e91a07ff1
    SHA256: a3b832240cb4115bd9f2d795a35745cb7787f1fa48c6dc35298e72cdbffb8ea1
    CRC32: 9286a7f5
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE21.3.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 609173504 字节 (580.95 MB)
    修改日期: 2022-03-25 11:41
    MD5: b4079186ad23607d546881bf01c5e9d0
    SHA1: 383e7a1a9f7f060a4fa67ae42e09034b0649ce0b
    SHA256: cf6304ec7fb69a3bd8c8a97d12509153914841b1ddaf097f1864edd23591660e
    CRC32: 50494273
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.3RTE64.txt (569 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 605526016 字节 (577.47 MB)
    修改日期: 2022-03-25 11:56
    MD5: 7a1fe67b77312f3e31e641e12652a530
    SHA1: ea159fd32fcaedd40c9b16f702db92728311d452
    SHA256: 49b1bd4e09b1a07f3309a85c6ce67fab49c2659fdfc932e6fca7407032b9b417
    CRC32: 697e3ae4
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.3RTE32.txt (581 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 21.3 Readme
    October 2021
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 21.3 includes the following new features:
    • Support for user-defined overlap (%) for Sequential FFT measurement method in ACP
    RFmx LTE 20.7 includes the following new features:
    • Support for IQ impairment compensation in uplink
    • Support for Time Alignment Error (TAE) measurement in downlink
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx LTE 21.3 supports the following 64-bit operating systems:
    Note    RFmx LTE no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx LTE 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx LTE 21.3 to an unsupported OS. Additionally, after installing RFmx LTE 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx LTE
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » National Instruments » RFmx LTE » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » National Instruments » RFmx LTE » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 21.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » National Instruments » RFmx LTE » RFmx LTE Examples.
    The following items are the behavior changes in RFmx LTE 20.7 from RFmx LTE 19.1
    The following items are behavior changes in RFmx LTE 19.1 from RFmx LTE 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxLTE Analyze (IQ) and RFmxLTE Analyze (Spectrum) APIs. Use RFmxLTE Analyze (IQ, 1 Wfm) and RFmxLTE Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx LTE 19.0 from RFmx LTE 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375558R-01
    GMT+8, 2026-2-3 06:36
