查看: 1697|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 21.5 x64Win10 32/64bitEng LTE/LTE演进蜂窝测试软件21.5
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 12:33:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2022/1/27
    包含的版本:21.5
    完整版校验和:
    文件大小: 1120606208 字节 (1.04 GB)
    修改日期: 2022-03-25 11:25
    MD5: 73c1fa21ef7913cb4d2f46a15df25014
    SHA1: 1ec35546f73009fef22d5af53c2c3c7fe9daab20
    SHA256: c54284ffb4a31cb156784c672f3539ef1ff53d6dc462d990c63ed11f0aff9a2a
    CRC32: a3438b58
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE20.7.1.txt (548 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 609773568 字节 (581.53 MB)
    修改日期: 2022-03-25 11:42
    MD5: e8b6af8598e1d3a5c632a1d66430c09f
    SHA1: 70be9de5b5071778c5ffa6d95901aa8b985621ce
    SHA256: ecdbb8d057eda2986b12c87b659f0841fad4f9aff7e826aae69c54a931b41ee0
    CRC32: 5c5aeb2e
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.7.1RTE64.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 606121984 字节 (578.04 MB)
    修改日期: 2022-03-25 11:58
    MD5: e9907423d1b671fc773e625f7b3e2789
    SHA1: a4508b69b82c57806db5a68550d917aebbe4c73d
    SHA256: 8697263dc356cb6cb20fe49c4f4a7bb0cd019bf584ea19cc0d2aadd26a27f40b
    CRC32: d572cb1c
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.7.1RTE32.txt (583 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 21.5 Readme
    January 2022
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 21.3 includes the following new features:
    • Support for user-defined overlap (%) for Sequential FFT measurement method in ACP
    RFmx LTE 20.7 includes the following new features:
    • Support for IQ impairment compensation in uplink
    • Support for Time Alignment Error (TAE) measurement in downlink
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx LTE 21.5 supports the following 64-bit operating systems:
    Note    RFmx LTE no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx LTE 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx LTE 21.5 to an unsupported OS. Additionally, after installing RFmx LTE 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx LTE
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » National Instruments » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » National Instruments » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 21.5 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » National Instruments » RFmx LTE Examples.
    The following items are the behavior changes in RFmx LTE 20.7 from RFmx LTE 19.1
    The following items are behavior changes in RFmx LTE 19.1 from RFmx LTE 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxLTE Analyze (IQ) and RFmxLTE Analyze (Spectrum) APIs. Use RFmxLTE Analyze (IQ, 1 Wfm) and RFmxLTE Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx LTE 19.0 from RFmx LTE 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    375558T-01
    GMT+8, 2026-2-3 06:37
