查看: 2089|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 21.8.1 x64Win10 32/64bitEng LTE/LTE演进蜂窝测试软件21.8.1
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 12:39:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2022/4/30
    包含的版本:21.8.1
    完整版校验和:
    文件大小: 1130317824 字节 (1.05 GB)
    修改日期: 2022-04-30 01:46
    MD5: e82acaee4c1d27512483793b2baf3432(官方正确)
    SHA1: f2201d250339a63c0db4d4012705b39338313fa7
    SHA256: 1da8951a822e4479451eaf9f3f8c13561fbcbbd3e60bd2ee20867fa970d348a3
    CRC32: ac524d58
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE21.8.1.txt (613 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 617306112 字节 (588.71 MB)
    修改日期: 2022-04-30 01:45
    MD5: d596adab039aa83739890aadaa59bab0(官方正确)
    SHA1: eb1b9dab96d136be686ace06c28978f412452c3f
    SHA256: 2f3dbcb6102d4a4f47963365f88a78181a8386010c7878e215818fb9c25788bc
    CRC32: fd86d758
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.8.1RTE64.txt (638 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 612519936 字节 (584.14 MB)
    MD5: 0ffc495b174514584285d0be7a83dc8e(官方正确)
    SHA1: b36940ff89e395758e04f217d2a6c9449003835b
    SHA256: 9adb44a09dd55e3b22593affa61b69311b432e4406aac22cdf440d2fa9f27699
    CRC32: 916de269
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.8.1RTE32.txt (650 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 21.8.1 Readme
    April 2022
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 21.3 includes the following new features:
    • Support for user-defined overlap (%) for Sequential FFT measurement method in ACP
    RFmx LTE 20.7 includes the following new features:
    • Support for IQ impairment compensation in uplink
    • Support for Time Alignment Error (TAE) measurement in downlink
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx LTE 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx LTE no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx LTE 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx LTE 21.8.1 to an unsupported OS. Additionally, after installing RFmx LTE 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx LTE
    ItemInstalled Location
    Import Library files
    Select Start » National Instruments » RFmx LTE » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » National Instruments » RFmx LTE » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » National Instruments » RFmx LTE » RFmx LTE Examples.
    The following items are the behavior changes in RFmx LTE 21.8 from RFmx LTE 21.5
    • Obsoleted Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following items are the behavior changes in RFmx LTE 20.7 from RFmx LTE 20.6
    375558V-01
    GMT+8, 2026-2-3 06:36
