查看: 1721|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 21.8.2 x64Win10 32/64bitENG RFmx蜂窝测试TD-SCDMA21.8.2
    11 小时前
  • 签到天数: 3823 天
    连续签到: 16 天
     楼主| 发表于 2022-7-13 17:16:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2022/6/30
    包含的版本:21.8.2
    完整版校验和:
    文件大小: 1073360896 字节 (1023.64 MB)
    修改日期: 2022-06-30 09:47
    MD5: 01e46aaea1947c1153f0a70cb58a1d5a
    SHA1: 5eeb70c1c6a63abbb4dd7bd748698c69e6033c56
    SHA256: 6677f6a925f594ea494a9c534370a0adf43b76d8e64f94b17352dd6977d3f79c
    CRC32: 1aa9c395
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx TD-SCDMA21.8.2.txt (553 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 606840832 字节 (578.73 MB)
    修改日期: 2022-06-29 21:49
    MD5: d7398cf3151ebb18559aa8b02e52d9d8
    SHA1: 8bbb846bb028404c922feff35c0055617d21ec8f
    SHA256: 82380151abbc8659d28765cb9a198015cd00f5d9f6eed58f78b62a9e689cd0b7
    CRC32: dfebdef3
    NI官方下载和百度网盘下载地址:
    RFmx TD-SCDMA21.8.2RTE64.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 602234880 字节 (574.34 MB)
    MD5: aea99cd3dfbfb99b95f31e19f0d91202
    SHA1: 66d7ed27c2658784f2f21fea2bbc20a42efdbe60
    SHA256: 978ad53cd9ded4460d791e87a5ba8694d0739c7de783c6e2f8802c48f2a4e29e
    CRC32: 7b19ee55
    NI官方下载和百度网盘下载地址:
    RFmx TD-SCDMA21.8.2RTE32.txt (587 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 21.8.2 Readme
    May 2022
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 21.3 includes the following new feature:
    RFmx TD-SCDMA 20.0 includes the following new features:
    RFmx TD-SCDMA 19.1 includes the following new feature:
    RFmx TD-SCDMA 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 21.8.2 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx TD-SCDMA
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    ItemInstalled Location
    Import Library files
    Select Start » National Instruments » RFmx TD-SCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx TD-SCDMA HelpHTML/Windows HelpContains primary help content for RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx TD-SCDMA
    • A complete reference for all RFmx TD-SCDMA programming functions and VIs
    RFmx TD-SCDMA 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    • Obsoleted RFmxTDSCDMA Analyze (IQ) and RFmxTDSCDMA Analyze (Spectrum) APIs. Use RFmxTDSCDMA Analyze (IQ, 1 Wfm) and RFmxTDSCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx TD-SCDMA 19.0 from RFmx TD-SCDMA 3.0:
    • Dropped support for RFmx TD-SCDMA Measurement Interactive Panel
    375525V-01
    GMT+8, 2026-3-12 20:07
