查看: 1746|回复: 0
[NI软件产品] NI RFmx NR 3.0 Win32/64ENG RFmx 5G新空口蜂窝测试3.0
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-14 09:45:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2019/1/17
    包含的版本:3.0
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    完整版校验和:
    文件大小: 743628744 字节 (709.18 MB)
    修改日期: 2022-03-25 22:18
    MD5: 1c70da9f4515a845fafe7ce7dc144015
    SHA1: 3037ff8d5f60ee4ca27d0d2aa9babac7f54174bb
    SHA256: 6cb75609113397c4ec8a4803068d2b77616f3f0af81441a94e481d2ad60ba2c8
    CRC32: 74921874
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR3.0.txt (481 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 355975176 字节 (339.48 MB)
    MD5: db41263c9e3585f70bd2a9e4723ad7ed
    SHA1: 207b69739ed4c258cebf48d40b95e3242c1211cb
    SHA256: fb4d3aee654ca5fc66a573b20c98e57bd1929b2d49d6ddef56e0faccbdb01c2f
    CRC32: 0a81b604
    NI官方下载和百度网盘下载地址:
    RFmx NR3.0RTE64.txt (493 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 362221544 字节 (345.44 MB)
    MD5: 4c82f6ac9b324dbb3ebe957482c9ff4a
    SHA1: d5c9a54a45c600c253ed1b29a35459e49e607cd3
    SHA256: 563a3f60527893b250ec24b8ae56d93c858855a870020815ff79076eaad6a9de
    CRC32: 34746559
    NI官方下载和百度网盘下载地址:
    RFmx NR3.0RTE32.txt (493 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx NR 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx NR and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx NR supports the following features:
    • Support for modulation accuracy, occupied bandwidth, channel power, adjacent channel power, spectral emission mask measurements for FR1 and FR2 channel bandwidths, and subcarrier spacings as mentioned in 3GPP TS 38.101-x and 3GPP 38.104 (v15.4.0) specifications
    • Support for modulation accuracy measurement of the following physical channels and reference signals as mentioned in 3GPP TS 38.211 (v15.4.0) specification
      • PUSCH, PDSCH physical channels
      • DM-RS, PT-RS reference signals
    • Support for intra-band contiguous carrier aggregation
    Installation InstructionsCaution  Before you install NI-RFmx NR 3.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx NR 3.0 supports the following operating systems:
    Note  NI-RFmx NR 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx NR. To add support for ADEs installed after installing NI-RFmx NR, modify your NI-RFmx NR installation or launch the NI-RFmx NR installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx NR does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\NR\Examples
    Examples\LabVIEW \examples\RFmx\NR
    Select Start»All Programs»National Instruments»NI-RFmx NR»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Documentation for NI-RFmx NR is located at Start»All Programs»National Instruments»NI-RFmx NR»NI-RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx NR HelpHTML/Windows HelpInformation about NI-RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx NR
    • A complete reference for all NI-RFmx NR programming functions and VIs
    NI-RFmx NR 3.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx NR palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    You can access all the installed NI-RFmx NR examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx NR»NI-RFmx NR Examples.
    If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2019 National Instruments. All rights reserved.
    377911A-01
    GMT+8, 2026-2-3 05:25
