查看: 1666|回复: 0
[NI软件产品] NI RFmx NR 19.0 Win32/64ENG RFmx 5G新空口蜂窝测试19.0
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-14 09:49:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2019/6/27
    包含的版本:19.0
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 926609408 字节 (883.68 MB)
    修改日期: 2022-03-25 22:18
    MD5: 0bcbcf9895928bec9502a09e465158d8
    SHA1: 9fd2da241a6a341eae6714e9888b63fd93a45474
    SHA256: b653466516f097523b608c737be6c4ad03d2c00033109dad573274b66a2f56ae
    CRC32: 57163883
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR19.0.txt (511 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 572467200 字节 (545.95 MB)
    MD5: f056edd6b98f842c7a6a778e9d093367
    SHA1: 690f6a045685299d9b3525c5ef93b6f34eee491f
    SHA256: 2b4296075f3df464489d8b885b6d38b3176a380630b830fa25d14b2c5a041ca8
    CRC32: 6c3ca897
    NI官方下载和百度网盘下载地址:
    RFmx NR19.0RTE64.txt (527 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 578875392 字节 (552.06 MB)
    MD5: 6973f44d3eb8763db524bf975f2bc88c
    SHA1: f25e984b128aeff9ca665ed22efdce5d644eede6
    SHA256: 97c38537000f726ba1acab7d74df24f285ca8acd9799972d42271eb8598c7e50
    CRC32: 0292aa15
    NI官方下载和百度网盘下载地址:
    RFmx NR19.0RTE32.txt (535 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 19.0 Readme
    June 2019
    This file contains important information about RFmx NR, including installation instructions, new features, bugs fixes, and known issues.
    RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 19.0 includes the following new features:
    • Addition of downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (v15.0.0, January 2019 Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Addition of uplink contiguous carrier aggregation in ACP measurement
    • Addition of EUTRA-NR dual connectivity (ENDC) in ModAcc, ACP, and SEM measurements
    • Support for configurable SSB active blocks
    • Support for uplink spectral flatness measurement for PI/2 BPSK with power boost
    • Support for auto phase compensation based on carrier frequency
    • Support multiple PUSCH configurations
    • Shared Channel symbol power is reported per carrier
    • Removed support for Cell ID control in DL Test Model Examples
    • Improvements in auto-detection of RB allocation
    • Support for PXIe-5830 (EAP) and PXIe-5831 (EAP)
    RFmx NR 3.0 includes the following new features:
    • Support for modulation accuracy, occupied bandwidth, channel power, adjacent channel power, spectral emission mask measurements for FR1 and FR2 channel bandwidths, and subcarrier spacings as mentioned in 3GPP TS 38.101-x and 3GPP 38.104 (v15.4.0) specifications
    • Support for modulation accuracy measurement of the following physical channels and reference signals as mentioned in 3GPP TS 38.211 (v15.4.0) specification
      • PUSCH, PDSCH physical channels
      • DM-RS, PT-RS reference signals
    • Support for intra-band contiguous carrier aggregation
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5831 (EAP)
    RFmx NR has the following requirements:
    • 4 GB RAM*
    RFmx NR 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx NR dropped support for all 32-bit Windows operating systems. RFmx NR will not install or run on an unsupported OS. Refer to RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx NR. To add support for application software installed after installing RFmx NR modify your RFmx NR installation or launch the RFmx NR installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx NR
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs RFmx NR using NI Package Manager. If you do not already have NI software installed, RFmx NR installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed SoftwareInstalled Software
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\NR\Examples
    Examples\LabVIEW \examples\RFmx\NR
    Select Start»All Programs»National Instruments»RFmx NR»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx NR examples at Start»All Programs»National Instruments»RFmx NR»RFmx NR Examples.
    Documentation for RFmx NR is located at Start»All Programs»National Instruments»RFmx NR»RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpInformation about RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 19.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx NR palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    The following items are the behavior changes in RFmx NR 19.0 from RFmx NR 3.0.
    Dropped support for LabVIEW 2015Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstrTo load and run a Downlink configuration file saved from RFmx 3.0, the user has to explicitly set value of Downlink Channel Configuration Mode property to User DefinedBug Fixes
    The following items are the IDs and titles of a subset of issues fixed in RFmx NR. This is not an exhaustive list of issues fixed in the current version of the RFmx NR. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx NR 19.0 from RFmx NR 3.0.
    732886Fixed an issue where querying the ACP Results Subblock Center Freq property returned an incorrect value.
    731766Fixed an issue where the trace for demodulated bits is not correct for 16QAM, 64QAM and 256 QAM.
    731670Fixed an issue where RFmxNR DL EVM shows a positive value on selecting unit to dB.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    RFmx NR will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2018–2019 National Instruments. All rights reserved.
    377911B-01
    GMT+8, 2026-2-3 05:26
