查看: 2042|回复: 0
[NI软件产品] NI RFmx NR 20.0 Win32/64ENG RFmx 5G新空口蜂窝测试20.0
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-14 09:57:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2020/6/9
    包含的版本:20.0
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 1334269952 字节 (1.24 GB)
    修改日期: 2022-03-25 12:18
    MD5: efbaca366f4b61ec902a146e9d6a7a05
    SHA1: 24424fb77ef534052ddec4f92acd5b101a793802
    SHA256: 66927a491f24e1613cf9f2a1f0f59d860a877a50048cc375d7796497def40f1e
    CRC32: 50899561
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR20.0.txt (527 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 591966208 字节 (564.54 MB)
    修改日期: 2022-03-25 12:48
    MD5: 7047e3fbd1487c89c1b00dec02b70447
    SHA1: 5d257209de4bc59b3da77accf032877798761b96
    SHA256: a87836f53dc7877229270e05751721c26b9f95db4ca27327952e28ab96649f50
    CRC32: 70139978
    NI官方下载和百度网盘下载地址:
    RFmx NR20.0RTE64.txt (552 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 589047808 字节 (561.76 MB)
    修改日期: 2022-03-25 13:05
    MD5: c758359399f390f2eb2d218f62e66bba
    SHA1: 66b686b8298d061baf9a358e0255c2f7b010bad1
    SHA256: 115dda3f3df2796924ecf64835e1d08ec65becb9e4d104151571722bfb31e3c7
    CRC32: eca71beb
    NI官方下载和百度网盘下载地址:
    RFmx NR20.0RTE32.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 20.0 Readme
    June 2020
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 20.0 includes the following new features:
    • Support for updates from 3GPP TS 38.104 NR Release 16 specification March 2020
    • Support for PUSCH and PDSCH DMRS for Release 16 as per 3GPP TS 38.211 specification v16.1.0
    • Support for Downlink Test Model 2a and 3.1a for Frequency Range 2
    • Support for 1024 QAM modulation in PDSCH and PUSCH
    • Support for user defined Downlink Multi-user configuration
    • Support for Downlink SS/PBCH EVM in ModAcc measurement for Case A-E
    • Speed improvements in ModAcc measurement
    • Support for speed optimization of the ModAcc measurement by bypassing certain operations
    • ModAcc robustness improvements for low RB allocations in PDSCH/PUSCH
    • Support for Sequential FFT in ACP for measurement bandwidth greater than device instantaneous bandwidth in PXIe-5830/5831/5840/5841
    • Support for measurement bandwidth equal to channel bandwidth in CHP measurement
    • Support for Bandwidth Optimization Enabled mode in composite measurements
    RFmx NR 19.1 includes the following new features:
    • Support for PXIe-5830/5831/5841
    • Support for updates from 3GPP NR Release 15 specification v15.6.0 (June 2019)
    • Support for non-contiguous carrier aggregation
    • Support for power vs time (PVT) measurement for Uplink
    • Support for additional offset channel spacing for carrier aggregation in the ACP measurement
    • Support for auto increment cell id for carrier aggregation
    • Support for PDSCH EVM measurement in the presence of PDCCH
    • Enhanced robustness of ModAcc measurement to analyze filtered waveforms, sequence and group hopping, and impaired signals
    • Added capability to include/exclude DMRS and PTRS EVM in Composite EVM result
    RFmx NR 19.0 includes the following new features:
    • Addition of downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (v15.0.0, January 2019 Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Addition of uplink contiguous carrier aggregation in ACP measurement
    • Addition of EUTRA-NR dual connectivity (ENDC) in ModAcc, ACP, and SEM measurements
    • Support for configurable SSB active blocks
    • Support for uplink spectral flatness measurement for PI/2 BPSK with power boost
    • Support for auto phase compensation based on carrier frequency
    • Support multiple PUSCH configurations
    • Shared Channel symbol power is reported per carrier
    • Removed support for Cell ID control in DL Test Model Examples
    • Improvements in auto-detection of RB allocation
    • Support for PXIe-5830 and PXIe-5831
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx NR has the following requirements:
    RFmx NR 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx NR dropped support for all 32-bit Windows operating systems. RFmx NR will not install or run on an unsupported OS. Refer to RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx NR dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx NR 20.0 to an unsupported OS. Additionally, after installing RFmx NR 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. To add support for application software installed after installing RFmx NR modify your RFmx NR installation or launch the RFmx NR installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx NR
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx NR using NI Package Manager. If you do not already have NI software installed, RFmx NR installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx NR » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx NR palette VIs are available from the Functions » Measurement I/O » NI-RFmx » NR palette.
    Documentation for RFmx NR is located at Start » All Programs » National Instruments » RFmx NR » RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpContains primary help content for RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx NR examples at Start » All Programs » National Instruments » RFmx NR » RFmx NR Examples.
    The following are the behavior changes in RFmx NR 20.0 from RFmx NR 19.1.
    • Updated measurement bandwidth for Uplink FR2 contiguous CA in ACP and CHP
    • Frequency segment definition of Operating Band Unwanted Emission in SEM measurement aligned with section 9.7.4.3.3 of 3GPP TS 38.104 specification v15.9.0/v16.3.0
    • NR SS/PBCH block parameters CRB Offset and Subcarrier Offset in ModAcc measurement are aligned to be 3GPP specification compliant
    The following are the behavior changes in RFmx NR 19.1 from RFmx NR 19.0.
    • Change in default value of Transmit LO Architecture property to LO per Subblock. In this mode:
      • IQ Origin offset result for multicarrier configurations is reported in Subblock IQ Origin Offset Mean result property
      • Quadrature error and IQ Gain Imbalance results are not supported for multicarrier configurations
    • Updated nominal spacing definition for carrier aggregation cases as per Rel 15 Specification June 2019 v 15.6.0. For waveforms compliant to previous Rel 15 releases, use user-defined spacing definition.
    • Composite EVM result does not include the EVM of DMRS and PTRS. You must set ModAcc Composite Results Include DMRS and ModAcc Composite Results Include PTRS properties to True to include the respective EVMs in the Composite EVM result
    • Dropped support for ModAcc EVM Exclusion Period property for Downlink measurement as per the 3GPP NR specification Rel 15 June 2019
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and 5831
    • Obsoleted RFmxNR Analyze (IQ) and RFmxNR Analyze (Spectrum) APIs. Use RFmxNR Analyze (IQ, 1 Wfm) and RFmxNR Analyze (Spectrum, 1 Wfm) APIs instead
    • When you set the Frequency Range property to Range 2 , the new enums, FR2 Category A , FR2 Category B , added to the gNodeB Category property are the only valid enums.
    The following are the behavior changes in RFmx NR 19.0 from RFmx NR 3.0.
    • To load and run a Downlink configuration file saved from RFmx 3.0, the user has to explicitly set value of Downlink Channel Configuration Mode property to User Defined
    You can access the RFmx NR known issues list online at RFmx NR 20.0 Known Issues.
    You can access the RFmx NR bug fix list online at RFmx NR 20.0 Bug Fixes.
    RFmx NR will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2018–2020 National Instruments. All rights reserved.
    377911D-01
    GMT+8, 2026-2-3 05:26
