查看: 1691|回复: 0
[NI软件产品] NI RFmx NR 20.7.1 x64Win10 32/64bitENG RFmx 5G新空口蜂窝测试20.7.1
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-14 10:06:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2021/7/20
    包含的版本:20.7.1
    完整版校验和:
    文件大小: 1431087104 字节 (1.33 GB)
    修改日期: 2022-03-25 12:30
    MD5: 54198b1b644a448f1287af4bbb9d64ad
    SHA1: 24a8928c21f8ffdc8dacb2611eb0061638b41e71
    SHA256: 7a19b6956b061c9623da9d3a7a029de16483798109b4f184ad9d078460dc798c
    CRC32: 367bdb6c
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR20.7.1.txt (529 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 625098752 字节 (596.14 MB)
    修改日期: 2022-03-25 12:55
    MD5: 0843f289aecb42dbcc8f381a82c720a1
    SHA1: 6e32341353be61acf82eb3ab3a95f63e8531adc7
    SHA256: 14040f138ff9bba05bc574c9eedd3d9f0383a16e34e7dccf96e4c62f5a7a7921
    CRC32: b588411d
    NI官方下载和百度网盘下载地址:
    RFmx NR20.7.1RTE64.txt (554 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 621217792 字节 (592.44 MB)
    修改日期: 2022-03-25 13:10
    MD5: 497a7fa8891176fe6aea297b8e4c4bcf
    SHA1: 7941f86c15b0653750d61dc4167d4b30ecea574c
    SHA256: f4b298f56c9d658be922aaf78392bec4426e264fa90db073fc50373368f73f6b
    CRC32: c4bbbeaa
    NI官方下载和百度网盘下载地址:
    RFmx NR20.7.1RTE32.txt (566 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 20.7.1 Readme
    July 2021
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 20.7 includes the following new features:
    • Support for all Trigger Types and Synchronization Modes in ModAcc measurement for Downlink mixed numerology SSB/SCH configurations
    • ModAcc robustness improvements for Downlink mixed numerology SSB/SCH configurations
    • Support for user configurable grid size
    • Support for updates from 3GPP NR Release 16 specification December 2020
    • Support for 8-PSK modulation in downlink shared channel
    • Support for custom span in Occupied bandwidth (OBW) measurement
    • Support for IQ impairments compensation per subcarrier
    • Support for traces of IQ impairments compensation results
    • Support for Time Alignment Error (TAE)
    • Support of configuration of empty carriers in In-Band Emission (IBE) measurement
    • Support for Intraband Non-contiguous carrier aggregation in Uplink for the following spectral measurements:
      • Adjacent Channel Power (ACP)
      • Spectral Emission Mask (SEM) for FR1
      • Occupied Bandwidth (OBW)
      • Channel Power (CHP)
    RFmx NR 20.6 includes the following new features:
    • Support for updates from 3GPP TS 38.101-1/2 v16.4 specification in Adjacent Channel Power measurement to support intra-band contiguous carrier aggregation for FR1 and updates in Channel Measurement Bandwidth for FR2
    • Support for estimation of IQ impairments for receive model in ModAcc
    • Support for compensation of IQ impairments in ModAcc
    • Support for measurement of I/Q timing skew in ModAcc
    • Support for additional results in spectral flatness measurement
    • Support for additional bands: 14, 18, 29, 30, 48, 65, 90, 92, 94
    • Support for PUSCH 8-PSK modulation scheme
    • Support for PXIe-5832
    RFmx NR 20.0 includes the following new features:
    • Support for updates from 3GPP TS 38.104 NR Release 16 specification March 2020
    • Support for PUSCH and PDSCH DMRS for Release 16 as per 3GPP TS 38.211 specification v16.1.0
    • Support for Downlink Test Model 2a and 3.1a for Frequency Range 2
    • Support for 1024 QAM modulation in PDSCH and PUSCH
    • Support for user defined Downlink Multi-user configuration
    • Support for Downlink SS/PBCH EVM in ModAcc measurement for Case A-E
    • Speed improvements in ModAcc measurement
    • Support for speed optimization of the ModAcc measurement by bypassing certain operations
    • ModAcc robustness improvements for low RB allocations in PDSCH/PUSCH
    • Support for Sequential FFT in ACP for measurement bandwidth greater than device instantaneous bandwidth in PXIe-5830/5831/5840/5841
    • Support for measurement bandwidth equal to channel bandwidth in CHP measurement
    • Support for Bandwidth Optimization Enabled mode in composite measurements
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx NR has the following requirements:
    RFmx NR 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx NR no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx NR 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx NR 20.7.1 to an unsupported OS. Additionally, after installing RFmx NR 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx NR
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx NR » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx NR palette VIs are available from the Functions » Measurement I/O » NI-RFmx » NR palette.
    Documentation for RFmx NR is located at Start » All Programs » National Instruments » RFmx NR » RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpContains primary help content for RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx NR examples at Start » All Programs » National Instruments » RFmx NR » RFmx NR Examples.
    The following are the behavior changes in RFmx RFmx NR 20.7 from RFmx RFmx NR 20.6.
    The following are the behavior changes in RFmx NR 20.6 from RFmx NR 20.0.
    • Change in the following API names:
      • ModAcc:IQ Origin Offset Estimation Enabled to ModAcc:IQ Impairments:IQ Origin Offset Estimation Enabled
      • ModAcc IQ Impairments Estimation Enabled to ModAcc IQ Mismatch Estimation Enabled
      • ModAcc:IQ Impairments:Estimation Enabled to ModAcc:IQ Impairments:IQ Mismatch Estimation Enabled
    • Changed measurement limits for SEM in-band emission and spectral flatness measurement to the limits defined in 3GPP 38.141 and 3GPP 38.521 specifications
    • Renamed the below APIs:
    The following are the behavior changes in RFmx NR 20.0 from RFmx NR 19.1.
    • Updated measurement bandwidth for Uplink FR2 contiguous CA in ACP and CHP
    • Frequency segment definition of Operating Band Unwanted Emission in SEM measurement aligned with section 9.7.4.3.3 of 3GPP TS 38.104 specification v15.9.0/v16.3.0
    • NR SS/PBCH block parameters CRB Offset and Subcarrier Offset in ModAcc measurement are aligned to be 3GPP specification compliant
    The following are the behavior changes in RFmx NR 19.1 from RFmx NR 19.0.
    • Change in default value of Transmit LO Architecture property to LO per Subblock. In this mode:
      • IQ Origin offset result for multicarrier configurations is reported in Subblock IQ Origin Offset Mean result property
      • Quadrature error and IQ Gain Imbalance results are not supported for multicarrier configurations
    • Updated nominal spacing definition for carrier aggregation cases as per Rel 15 Specification June 2019 v 15.6.0. For waveforms compliant to previous Rel 15 releases, use user-defined spacing definition.
    • Composite EVM result does not include the EVM of DMRS and PTRS. You must set ModAcc Composite Results Include DMRS and ModAcc Composite Results Include PTRS properties to True to include the respective EVMs in the Composite EVM result
    • Dropped support for ModAcc EVM Exclusion Period property for Downlink measurement as per the 3GPP NR specification Rel 15 June 2019
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and 5831
    • Obsoleted RFmxNR Analyze (IQ) and RFmxNR Analyze (Spectrum) APIs. Use RFmxNR Analyze (IQ, 1 Wfm) and RFmxNR Analyze (Spectrum, 1 Wfm) APIs instead
    • When you set the Frequency Range property to Range 2 , the new enums, FR2 Category A , FR2 Category B , added to the gNodeB Category property are the only valid enums.
    You can access the RFmx NR known issues list online at RFmx NR 20.7.1 Known Issues.
    You can access the RFmx NR bug fix list online at RFmx NR 20.7.1 Bug Fixes.
    © 2018–2021 National Instruments Corporation. All rights reserved.
    377911G-01
    GMT+8, 2026-2-3 05:25
