查看: 1636|回复: 0
[NI软件套件] NI Data Record AD Development 1.0 x64Win10 64bitEng 自动驾驶数据记录开发套件1.0
    13 小时前
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-8-2 12:04:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Data Record AD Development自动驾驶数据记录开发套件
    Data Record AD Development套件用于创建和配置I/O插件、自定义Data Record AD、进行UI开发。
    Data Record AD Development套件包含Data Record AD Configuration Editor、Data Record AD Visualization工具包和Data Record AD Plug-In Creation工具包附加软件。这些附加工具扩展了Data Record Ad应用软件的功能,用于支持PXI上的ADAS和自动驾驶车载数据记录应用程序。
    发布日期:
    2021/5/21
    包含的版本:
    1.0完整版
    语言:
    English
    应用程序位数:
    64位
    文件大小: 4983177216 字节 (4.64 GB)
    修改日期: 2022-03-25 11:43
    MD5: 6b86346b4100108098284543dd00c2ac(官方正确)
    SHA1: ed4fa283cf678ef7451a121c41b240cb33fdce9f
    SHA256: 7d24ffd0e6dbf38b6058a9905955376eebbb05946ffd7c7ca4fbd6f17ce3c87d
    SHA512: 8f45989f1544231b39c56861297229a28b18e3f41320564e6358c61b9e4eb21be9debc453a520cfd5b97f2416132f406318998abd0e6d8957c7685ca330d52bc
    注册登录视觉论坛账号,购买附件查看下载地址
    自动驾驶数据记录开发套件1.0.txt (795 Bytes, 下载次数: 0, 售价: 20 圆)
    Data Record AD Development Suite 1.0 Readme
    June 2021
    This file contains important information about the Data Record Autonomous Driving Development Suite 1.0 (Data Record AD Development Suite), including installation instructions. The Data Record AD Development Suite is a pre-defined set of application software, instrument drivers, and related toolkits commonly required for developing, executing, debugging, and deploying datalogging programs on the Data Record System AD (Data Record System).
    • Data Record AD Development Suite Release Notes: Known issues and other notes about this release
    • Data Record AD Manuals
    Included Components
    Supported Controllers and Operating Systems
    Included Components
    The Data Record AD Development Suite 1.0 includes the following components:
    • Data Record AD Configuration Editor 1.0 (Configuration Editor)
    • Data Record AD Visualization Toolkit 1.0 (Visualization Toolkit)
    • Data Record AD Plug-In Creation Toolkit 1.0 (Plug-In Creation Toolkit)
    The Data Record AD Development Suite 1.0 has the following requirements:
    • 2.8 GHz Quad-Core Intel Xeon processor (or equivalent)
    • Minimum disk capacity of 160 GB
    • Minimum 8 GB of RAM
    • Minimum .NET Framework: 4.6.2
    The Data Record AD Development Suite 1.0 supports the following controllers:
    • PXIe-8861
    • PXIe-8880
    • PXIe-8881
    Note  The PXIe-8881 controller is functionally supported, but its high power consumption levels must taken into account during power budgeting.
    The Data Record AD Development Suite 1.0 supports the following operating system:
    • Windows 10 (64-bit only)
    The Data Record AD Development Suite 1.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    • LabVIEW 2020
    Download the Data Record AD Development Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    Refer to the Data Record System AD User Manual, accessible from ni.com/manuals, or the Data Record AD GitHub repository for information about the Data Record AD Development Suite.
    The .NET 4.6.2 installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software.
    © 2021 National Instruments Corporation. All rights reserved.
    378362A-01
    GMT+8, 2026-2-2 23:40
