查看: 2495|回复: 0
[LV工具模块] LabVIEW 2022 Q3 Control Design and Simulation Module Win11 32BitEng LV2022Q3控制设计和仿真模块CDSIM22.3
     楼主| 发表于 2022-8-4 12:02:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    CDSIM22.3
    发布日期
    2022/7/23
    包含的版本:2022 Q3完整版
    应用程序位数:32位
    文件大小: 608348160 字节 (580.17 MB)
    修改日期: 2022-07-23 09:54
    MD5: 44ce02a4cc2cfadd8829c75aa06d118e
    SHA1: b3b5f520ca3efdabba83e0851b7a5ee8d870758e
    SHA256: 49ae6fcac92e7d5d039d9431d61fda69b1f62cd90bf443935af63363deecad0f
    SHA512: deca122a9a89b25a8774f9f35c017bb6e36172aaeeb59accb39a4af542d146f610ba3aebd5db58268162ff1f9f7f3838b1ef64338c287c6867b88c1d60fd9af7
    CDSim2022Q3x86.txt (770 Bytes, 下载次数: 3, 售价: 10 圆)
    暂未更新自述文件,参考2021版自述文件。
    LabVIEW 2021 Control Design and Simulation Module Readme
    June 2021
    This file contains installation instructions and compatibility information for the LabVIEW Control Design and Simulation Module.
    • Manuals: New features, behavior changes, and other documentation
    Limitations on Windows (64-bit), macOS, and Linux
    The Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate dynamic systems, and deploy models and control systems to real-time hardware. The Control Design and Simulation Module also provides tools to complete the entire system identification process, which involves building mathematical models of a dynamic system based on a set of measured stimulus and response data samples.
    Use the Control Design Assistant to load and save models, perform analysis on systems, and design controllers. Refer to the Control Design Assistant Readme for information about the Control Design Assistant.
    Use the System Identification Assistant to create a project that encompasses the whole system identification process. Refer to the System Identification Assistant Readme for information about the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the Control Design and Simulation Module has the following requirements:
    • LabVIEW 2021 Full or Professional Development System
    • At least 800 MB of disk space
    • (Optional) LabVIEW MathScript Module for designing, analyzing, and simulating linear controller models using a text-based language
    The Control Design and Simulation Module supports the following operating systems:
    WindowsWindows 10 (version 1909)
    Windows Server 2016
    macOSmacOS 11 (x86_64 only) or 10.15
    LinuxopenSUSE LEAP 15.2
    openSUSE LEAP 15.1
    Red Hat Enterprise 8
    Red Hat Enterprise 7
    CentOS 8
    CentOS 7
    Ubuntu 20.04
    Ubuntu 18.04
    The following features are available on Windows:
    • Control Design Assistant
    • Real-Time support
    • System Identification VIs
    Download the Control Design and Simulation Model installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    (macOS, Linux)
    NI provides a repository add-on for all supported drivers that you can install using your Linux distribution's native package manager.
    • Visit ni.com/info and enter the Info Code LinuxRepository.
    • Download the installer for the repository add-on for your Linux distribution.
    • Install the repository add-on using the rpm command.
    • Select and install Control Design and Simulation Model driver packages through your Linux distribution's package manager.
    After the driver package(s) are installed, you must rebuild the new packages for the system kernel. NI recommends that you run the command 'dkms autoinstall' after installation, and before rebooting the system, to install the latest revision of all modules that have been installed for other kernel revisions. After doing so, the installed device drivers will function immediately on the next system start.
    (Windows) Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Control Design and Simulation Module.
    (macOS and Linux) Launch LabVIEW and select Help»Control Design and Simulation Module to launch the LabVIEW Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design User Manual for conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by navigating to the labview\manuals directory and opening CD_User_Manual.pdf.
    Refer to the LabVIEW Control Design and Simulation Module Algorithm References manual for information about algorithms implemented in the Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design and Simulation Module Algorithm References manual by navigating to the labview\manuals directory and opening CDreference.pdf.
    (Windows) Refer to the LabVIEW System Identification VIs Algorithm References manual for information about algorithms implemented in the System Identification VIs and their corresponding references. Access the LabVIEW System Identification VIs Algorithm References manual by navigating to the labview\manuals directory and opening SIreference.pdf.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Control and Simulation folder to access the LabVIEW examples for the Control Design and Simulation Module. You also can find the LabVIEW examples for the Control Design and Simulation Module in the labview\examples\Control and Simulation directory and the (Windows) labview\examples\System Identification directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Advanced Signal Processing Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2007–2021 National Instruments Corporation. All rights reserved.
    375312H-01
    GMT+8, 2025-12-8 07:32
